Old 08-18-2021, 01:39 PM   #1
OtherDude
Drives: 2020 BRZ, 2019 Veloster N
Gen2 Transmission swap?
So after reading/watching reviews on the new GR86, I've heard that Toyota (and almost certainly Subaru as well) have strengthened the transmission for the additional power and made cross-gate shifting better (2-3, 4-5). I even saw somewhere that they strengthened 4th specifically, which from reading through some posts here, seems like the most common failure point of these transmissions.
I was curious what we think of a Gen2 trans swap if a Gen1 car grenades it's trans. Being that it's the same chassis, I feel like it might just bolt up in the same spot with relative ease, but I'm not 100% confident.
Curious to hear everyone's thoughts
OtherDude is offline   Reply With Quote
Old 08-18-2021, 01:41 PM   #2
Ashikabi
Ashikabi's Avatar
Incredibly unlikely to fit. And then you have electronics to deal with. I wouldn't count on it working on any practical fashion
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
DarkPira7e (08-18-2021), soundman98 (08-18-2021)
Old 08-18-2021, 02:22 PM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I hope there is sarcasm here. The MT very likely will fit previous gens.
dragoontwo is offline   Reply With Quote
The Following 5 Users Say Thank You to dragoontwo For This Useful Post:
flippy (01-19-2023), Goingnowherefast (08-18-2021), kevaughan (03-24-2022), Petah78 (09-08-2021), SuperTom (03-25-2022)
Old 08-18-2021, 02:30 PM   #4
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I'd actually be pretty shocked if the transmission bellhousing didn't have the same bolt pattern. Mechanically, I'd bet it'll bolt in and the output is probably the same. The electronics may be different though.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 08-18-2021, 02:34 PM   #5
Ashikabi
Ashikabi's Avatar
Just like the turbo FA20 from the WRX fit so well? This isn't an LS where literally every engine made in the last 20 years was effectively identical. I hope I'm wrong, but if they changed the block at all, it's unlikely the bell housing is the same
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 08-18-2021, 02:47 PM   #6
dragoontwo
dragoontwo's Avatar
I doubt that the bellhousing changes. It is very likely the same transmission with a few upgrades(that have already been mentioned). On the electronics side of things if the plugs on the few sensors are different, the sensor threads are likely the same to swap the old sensors.
We will of course find out down the road when people start getting their hands on these.
Old 08-18-2021, 04:07 PM   #7
OtherDude
This is what I was thinking/hoping. I've seen a number of people stating that the engine still has the same base, with just some extra bore and probably new heads and whatever else, but not sure why they would have to change the bellhousing. And I doubt they would develop a whole new trans for Gen2 instead of just reinforcing the weakest parts.
I was more curious about the electronics. I'm not sure how much the electronics are involved with a MT. I know there's a gear indicator and some interfacing, but being that you operate most of it yourself, not sure how much of a dealbreaker electronics would be if they weren't compatible
Old 08-18-2021, 04:49 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
That was an AWD tranny with the starter on the other side. The FA20F block is not a FA20D block. Completely different castings. The FA24D could be the same castings that is just bored out. I don't know, but I doubt they changed the bellhousing or the basics from Aisin. The bellhousing could be swapped too.
I bet this thing will fit just fine. In fact, I plan to swap transmissions in the future. I might get the gen2 before doing a CD009 swap. A gen2 swap will be a minimum. A CD009 will be if I stay with this platform and want to bury another large chunk of money into said transmission while building my motor for more power.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
PulsarBeeerz (08-24-2021)
Old 08-18-2021, 04:50 PM   #9
dragoontwo
dragoontwo's Avatar
There is no gear indicator on the transmission itself. Should just be a reverse and neutral sensor.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Old 08-18-2021, 05:00 PM   #10
Goingnowherefast
Correct. People mix this up here all the time. The "indicated" gear is simply an internal calculation based on engine speed, vehicle speed, final drive ratio, and approximate tire diameter.
The Following 4 Users Say Thank You to Goingnowherefast For This Useful Post:
AT-JeffT (08-18-2021), jcw99 (09-09-2021), jeepmor (08-28-2021), kevaughan (03-24-2022)
Old 08-18-2021, 05:56 PM   #11
Grady
Grady's Avatar
No neutral sensor, just reverse to turn the back up lights and camera on and speed sensor for output shaft I believe. No electronics whatsoever in the manual.
The Following 2 Users Say Thank You to Grady For This Useful Post:
jeepmor (08-28-2021), SuperTom (03-25-2022)
Old 08-18-2021, 06:33 PM   #12
dragoontwo
dragoontwo's Avatar
Yes, there is a neutral switch on the transmission. There is no speed sensor on the mt.
The Following User Says Thank You to dragoontwo For This Useful Post:
Grady (08-23-2021)
Old 08-23-2021, 08:42 PM   #13
Grady
Grady's Avatar
Well I could not for the life of me figure out why the car needed to know neutral. You can’t start it in neutral. Dug into the wire manual and found it. It is tied into the cruse control. Tested it today kick the transmission in neutral without depressing the clutch it turns off cruse. Wonder who blew an engine doing that for them to add it?
The Following 6 Users Say Thank You to Grady For This Useful Post:
dragoontwo (08-23-2021), jcw99 (09-09-2021), jeepmor (08-28-2021), Ohio Enthusiast (08-23-2021), SuperTom (03-25-2022), Wally86 (03-25-2022)
Old 08-23-2021, 10:39 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
Did the auto transmission change? If not... Bolt-up seems likely.
I'm mostly ignorant on the gen2 stuff, but this one has me intrigued as a just-in-case I need to know some day.
transmission swap senpai_gt86 Engine, Exhaust, Transmission 2 05-14-2020 08:26 PM
Transmission swap Wilfred86 Engine, Exhaust, Transmission 6 10-04-2016 04:22 PM
Transmission swap ChrisD Engine, Exhaust, Transmission 6 04-04-2016 09:27 PM
transmission swap? VJZNAV Southern California 1 03-26-2014 11:57 PM
New hybrid drivetrain for Gen2 86? Mim Scion FR-S / Toyota 86 GT86 General Forum 28 09-17-2013 09:59 AM
