Old 08-23-2021, 07:21 PM   #1
billstock67
Drives: 2017 Toyota 86
Verus Carbon Fiber Driveshaft - New revision
Received new driveshaft & installed yesterday. Much different design from pictures on website. They assured me it was fully tested, and stronger than previous. Not sure why that was needed, or what they are correcting. Weight now over 15 lb. Have vibration at 80 mph and over. Waiting for Verus response.
billstock67 is offline   Reply With Quote
Old 08-23-2021, 07:29 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Response about what exactly?
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 08-23-2021, 07:46 PM   #3
StraightOuttaCanadaEh
Wes
Well that's not good. I also have vibration beyond 80 mph but with an alu driveshaft and was hoping a carbon one would take care of that.
Instagram: @gt86ws
Old 08-23-2021, 07:54 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Interesting. Maybe the design was changed for a universal jig application (vs per model production)
This is mine fresh from the box 2 years ago
Old 08-23-2021, 08:59 PM   #5
billstock67
Vibration issue.
Old 08-23-2021, 09:08 PM   #6
Joveen
Joveen's Avatar
Drives: Bone stock
But should you expect a lil bit of vibration at those speeds?
Old 08-23-2021, 09:10 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No. Vibration is really really hard on shit.
Old 08-25-2021, 03:38 PM   #8
FrickingReallySlow
Drives: 2015 FR-S
any other stiffening mods to the car like bushings etc? Also how many miles on your tranny, you can check the bushing between the driveshaft yoke inserts into the tranny to see if its been wiped
Originally Posted by billstock67 View Post
Vibration issue.
FrickingReallySlow is offline   Reply With Quote
Old 08-25-2021, 04:40 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
shouldnt vibrate at all.
back in time when i had RSX-S, i had aftermarket stiffened motor mounts which vibrates at idle which is normal but vibrating at driving is not normal. (educate me if incorrect)
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
JohnH (09-11-2021)
Old 08-25-2021, 04:45 PM   #10
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
@VerusEric Can you give any information on why you transitioned to CV joint on the driveshaft?
Old 08-25-2021, 10:03 PM   #11
billstock67
21K, poly bushing inserts in diff & subframe. Was smooth as silk before driveshaft. No other mods made at same time.
Old 08-25-2021, 10:22 PM   #12
billstock67
Not unexpected, Verus has requested that I rotate 90° and retest.
Will report back.
The Following User Says Thank You to billstock67 For This Useful Post:
Opie (08-26-2021)
Old 08-25-2021, 11:17 PM   #13
Wes
Will report back.
FWIW, I've rotated my - albeit - aluminum driveshaft through all 4 positions and some of them delayed the onset of vibration by maybe 2-3 mph, but not cured it. So I'm going back to stock.
Instagram: @gt86ws
Old 08-26-2021, 01:47 PM   #14
FrickingReallySlow
Drives: 2015 FR-S
Quite a lot of people have had the same experience. Do you also have trans/diff bushing / stiffer engine/trans mounts?
Current thinking is that the 2 shaft design was paired specifically with the potential NVH of 86 platform to remove vibrations and break potential resonance. Carbon fiber provided some dampening and people generally got better results compared to AL
It could be a self selection bias here where the only people that get one piece driveshafts are the ones that want stiffer response everywhere in the drivetrain by add stiffening, more NVH is added as input and the chassis + one piece driveshaft gives the resonant vibration transfer function. I also have a DSS aluminum without any bushing/mounts and its fine even to 105mph. Just a datapoint.
This is also assuming the tail bushing on your trans isn't wiped
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 10:22 AM
Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] acj47 Transmission and Driveline 2 10-25-2017 06:07 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
