Old 08-09-2021, 11:36 AM   #239
Ernest72
Originally Posted by jflogerzi View Post
Dump it for an axle back if you still have the stock mid pipe
Tried that and it was louder with a Borla axle back. I have mid pipe, what axle back is relatively quiet.
Old 08-09-2021, 05:21 PM   #240
jflogerzi
jflogerzi's Avatar
https://www.ftspeed.com/part/360-231...016-subaru-brz
Or a full MXP SP catback
2013 Series 10 FRS #553
Old 08-23-2021, 09:41 AM   #241
worldwidewait
Drives: GT86
I just installed 4 of these STI hangers. It took away almost 80% of the drone.
I have a kakimoto regu 06&r and it had a horrible drone starting from 2K rpm right up to 4+k. Now the drone is almost eliminated.
I noticed that the front pipe is bolted to the chassis unlike the rear muffler. Has anyone retrofitted a rubber hanger here as well?
worldwidewait is offline   Reply With Quote
The Following 2 Users Say Thank You to worldwidewait For This Useful Post:
DylanJZA (09-06-2022), kevaughan (10-04-2021)
Old 08-23-2021, 09:58 AM   #242
Calum
That Guy
Drives: 2013 asphalt FRS MT
Interesting question.
Old 08-23-2021, 03:50 PM   #243
gpvecchi
gpvecchi's Avatar
Mmh, too high temperatures for rubber?
OT: @worldwidewait are you on catless headers?
Old 08-24-2021, 03:55 AM   #244
worldwidewait
Drives: GT86
Yes. On Tomei UELs. It would still drone on stock headers. These kakimotos are pretty notorious. Even with 2 helmholtz resonators at the back p
Old 10-01-2021, 05:52 AM   #245
Compelica
Compelica's Avatar
Drives: 86 GT
Finally got to the spectrometer readings. Haven't done a full comparison yet but you can certainly see a 1-2 DB reduction at the lowest frequency peaks. I'll leave it to you guys to interpret the results.
Butt dyno wise on the road there is definitely less lower frequencies removed. In my setup it is the low frequencies which you can hear, not the frequencies you can feel. My setup does not have much drone or any, so to speak.
Setup is stock decatted header + stock overpipe + stock front pipe + Fujitsubo Authorize R catback. Mic used is a Boya BY-M1 (better than the stock phone mic at the very least).
Order of images is in 2K RPM, 3k, 4k, 5k, idle.
Before:
https://imgur.com/a/IRDlD5F
After:
https://imgur.com/a/SPBoV7q
A quote from a google link:
The standard definition of a decibel indicates that it’s roughly the smallest amount of volume change that a person can subjectively perceive. That means variations of up to 1 dB ought to be pretty much imperceptible, while those at or beyond 1 dB are noticeable.
https://www.logison.com/blog-article...hange-isntgood
Compelica is online now   Reply With Quote
The Following 5 Users Say Thank You to Compelica For This Useful Post:
DarkSunrise (10-01-2021), gpvecchi (10-02-2021), jeepmor (03-02-2022), kevaughan (10-02-2021), spcmafia (10-01-2021)
Old 10-03-2021, 07:56 PM   #246
warhawk03
Drives: 2018 BRZ
I installed a Fujitsubo Authorize R cat-back and the Subaru JDM hangers and noticed that there's a lot of movement with these hangers compared to stock. I can move the exhaust back and forth pretty easily and bump into the diff. For street driving this may be okay, but I'm curious if autocross may make it more noticeable.
warhawk03 is offline   Reply With Quote
The Following 2 Users Say Thank You to warhawk03 For This Useful Post:
kevaughan (10-04-2021), Overdrive (10-04-2021)
Old 10-04-2021, 12:19 AM   #247
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly. We pointed this topic some months ago. The original STi exhaust install spec was to change just the last 2 hangers. It would be easy for them to tell changing all of them, but I suppose they wanted to avoid the additional exhaust move.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Overdrive (10-04-2021), warhawk03 (10-04-2021)
Old 10-04-2021, 02:28 PM   #248
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Thanks for the reminder. I might opt to just do the rear 2 hangers. As soon as these mounts arrive
kevaughan is offline   Reply With Quote
Old 10-04-2021, 03:02 PM   #249
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Same thing here. I changed all of the hangers and noticed how much more movement there is from the system. I'll swap some of the originals back in and see if it cuts down on the movement.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
nikitopo (10-05-2021)
Old 10-04-2021, 07:27 PM   #250
warhawk03
Drives: 2018 BRZ
Sorry, I must've missed it earlier in the thread. Thanks for confirming.
The Following User Says Thank You to warhawk03 For This Useful Post:
nikitopo (10-04-2021)
Old 10-04-2021, 11:33 PM   #251
matthui95
matthui95's Avatar
Drives: 2018 CWP Subaru BRZ Sport-tech RS
Bit of a long shot but figured I'd ask since some of the guys here are from Toronto. Anyone wanna do a combined order, save on a bit of shipping for some hangers?
matthui95 is offline   Reply With Quote
Old 10-05-2021, 04:13 PM   #252
StraightOuttaCanadaEh
Wes
Missed me by a month or so! I ordered mine from blackhawkjapan and honestly wasn't too bad. Delivered fast and no duties
Instagram: @gt86ws
Ecutek discovery solidsnake11 Software Tuning 7 08-25-2020 07:38 AM
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 10:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
