Old 08-19-2021, 07:58 PM   #1
Ossiko
Drives: 2015 BRZ Limited
Mechanic said my compressor is going bad.
Hi all, I'm new to this forum and I recently just bought my first car, a 2015 BRZ Limited, and it came to my attention that my compressor was going out? When I checked it out while the car was running I noticed that the compressor cycles in and out every 30-40 seconds give or take. It also seems to mess with my RPM's a bit. Now I dont know much about cars, so I thought id get a second opinion and see what you folks have to say.
Thanks.
Ossiko is offline   Reply With Quote
Old 08-19-2021, 08:13 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Thanks.
Your ac compressor? Yea the clutch turns on and off quite often, that's normal. Unless it's not blowing cold air I don't know why you would want to replace it.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 08-19-2021, 08:16 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
Is it making and loud rattling noises when it is running?
Jdmjunkie is offline   Reply With Quote
Old 08-19-2021, 09:24 PM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's normal for the clutch to cycle, it's normal for the RPMs to fluctuate *a bit* when the the engine has to adjust for the increased load caused by the compressor.
The clutch cycling fast, like coming for a few seconds the releasing, then clutching again for a few seconds, not cycling at all, or a melted pulley from the clutch trying to couple a seized compressor to a moving belt or abnormal noises like the grinding of internal parts or the roaring of bearings, would be outwards indicators of a bad compressor.
It's hard to say without hearing it, but I've known of shops that regularly threw compressors at cars for nearly every AC concern. A 30-40 second cycle, depending on the atmospheric conditions isn't alarming and if it's blowing lots of cold air and not making noises, I wouldn't be inclined to replace it for fun.
Old 08-19-2021, 10:00 PM   #5
Ossiko
It’s blowing cold air, that’s why I don’t get it.
Old 08-19-2021, 10:00 PM   #6
Ossiko
I’m not sure, it might just be normally running? I could give a video for further details
Old 08-19-2021, 10:05 PM   #7
Ossiko
Well I’m not sure, because when he said this to me, and I know nothing about cars, so it was concerning to me. It blows cold air perfectly fine, when the car is in idil, the engine runs, then for a second as the compressor cycles you can hear your RPMs drop a bit, then it picks up again, and the cycle continues etc. Weather was about 80ish degrees and humidity was about 80-90% so I wouldn’t think the ambient had anything to do with it, but I could be wrong
Old 08-19-2021, 11:00 PM   #8
BlOody_BoOger
Yea dude that's perfectly normal. I could show you a video of my car doing that exact same thing.
Old 08-19-2021, 11:01 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like you need a replacement mechanic...
Old 08-19-2021, 11:12 PM   #10
Ossiko
Sure if you wouldn’t mind
Old 08-19-2021, 11:13 PM   #11
Ossiko
To be fair I just moved up here lol
Old 08-19-2021, 11:22 PM   #12
BlOody_BoOger
You got an Instagram account I can send it to real quick
Old 08-19-2021, 11:26 PM   #13
Ossiko
Sure do. Look up yixossiko
Old 08-20-2021, 01:10 AM   #14
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You should tell us the name of the shop and the city where this mechanic works so that we all know to stay away from it.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
AC Compressor Joesurf79 Engine, Exhaust, Bolt-Ons 8 05-28-2018 09:22 AM
AC Compressor Joesurf79 Engine, Exhaust, Bolt-Ons 0 05-22-2018 10:22 AM
Ls a/c compressor Parman Engine Swaps 1 11-20-2017 08:45 PM
AC compressor derek1ee Interior Parts (Incl. Lighting) 0 06-03-2016 01:17 AM
Air compressor for air tools? bleox Other Vehicles & General Automotive Discussions 17 12-30-2015 06:02 PM
