Old 08-27-2019, 03:02 PM   #43
aceangel
aceangel's Avatar
Drives: 13 BRZ WRB LTD 6AT
Originally Posted by Jameson86 View Post
I have the same fuel issue
I keep getting this recently on my BRZ. I might try the above about the fuel senders (FYI, I'm on 91 fuel). Mine happens at 3/4 of a tank (not even near empty)!
aceangel is offline   Reply With Quote
Old 08-19-2021, 06:16 PM   #44
UchihaFanBoy
UchihaFanBoy's Avatar
Drives: 16 BRZ,99 Forester,13 FRS(RIP)
Just got this. Any solution ?
UchihaFanBoy is offline   Reply With Quote
Old 08-19-2021, 07:02 PM   #45
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Celadrielas View Post
At risk of making this over complicated, the OFT could actually assist in this, though the tune itself is possibly unrelated. If are looking at or logging, please let me know what your RPM, Throttle %, FLKC, FBKC, IAM, STFT and LTFT are.
This will tell us if you are having knock, your fuel trims for short term and long term, What throttle percentage, and RPM you're at.
On the other had, usually if you were knocking bad enough, you'd be having other CEL, so it could be the sensor itself.
Log RPM, throttle position, knock, intake air temp and short and long term fuel trims.
For a Fuel Level Sensor issue.
WHY?
Do you enjoy making people run around on wild goose chases? Are you a bot that asks this of everyone with a Check Engine light? Maybe even a prerecorded customer support message!? "Hello, thank you for contacting customer support, to hasten the automated process please have your engine parameters on hand, if you do not have your engine parameters on hand, please stand by for a live operator."
p0463,P013f and c1237 codes? feldy Engine, Exhaust, Transmission 28 12-15-2015 12:02 AM
Unichip throwing p0102 code ?? jdubz13frs Software Tuning 3 07-10-2014 04:27 PM
OBDII Bluetooth and Torque app, throwing CEL BRZPDX Issues | Warranty | Recalls / TSB 11 03-03-2014 03:03 PM
Throwing the gauntlet down. Gran Turismo or Forza? Sully Off-Topic Lounge [WARNING: NO POLITICS] 153 01-03-2014 02:27 PM
Throwing around an idea DrDuquette BRZ First-Gen (2012+) — General Topics 18 08-04-2012 09:27 AM
