#5013 | |
2013 Series 10 FRS #553
#5014 |
Any advice on scrubbing RE71rs? I am reading conflicting posts online. From what I gather warm them up a bit and then let them sit 24 hours. What kind of driving can be done to warm them up(Canyon?) and for how long before cool down?
#5015 |
Drives: '13 Whiteout
#5016 |
Drives: 2017 BRZ limited PP WRC Blue
I probably should check Temps before making the jump and dialing in that much camber. If you jump onto the STX prep thread, there are a bunch of autox guys running -4 degrees. I may just end up going with -3.5 at most.
#5017 |
I'd stay there. I think you'll find that's pretty damn good. STX is a totally different car. I'm guessing with the extra weight and possibly more body roll the -4 works
#5018 |
Drives: Subaru BRZ
#5019 |
Drives: 2020 Subaru BRZ PP
Hi Mike,
I'm new to 200tw tires and had some quick questions on the treadwear on my RE-71Rs (photo below, driver's front). These tires have around 500 street miles plus one track day. I'm still at stock camber, so I'm sure adjusting that will help and I plan to handle that before the next yeah day. It also looks - to my novice eye - like I let them overheat a bit. Questions: 1. Driver's front is by far the worst. Is this tire shot or can I do another track day on it? 2. If I can put another track day on them, should I have my tire shop switch the front tires? 3. If I can put them through another day, will I be able to get home on them? In retrospect, jumping straight from the Primacy to the RE-71R was probably a bit ambitious Thanks for any insight! https://photos.app.goo.gl/1Bs99YATA7mA5Ujj8 |
#5020 | |
Drives: Crapcan
#5021 |
This is where my inexperience with 200tw tires is tripping me up haha. The left side of that center strip is down to the wear bars, but the rest of the tire is mostly still fine. I just wasn't sure if that center part was going to be a problem.
#5022 |
Drives: Crapcan
I didn't see that before. It is not that big of a deal, my RT660's are the same way. You should be able to run those to the cord. Though I am curious what you are running for hot pressure. Shoulders don't look that worn.
#5023 | |
Drives: Nevermorange FRS
So you're left with 1 option: Rotate your tires a lot. Thanks to a quick jack, I rotate tires every session (rule limited to -3.5) but my tires do wear much faster. You could probably get away with 2-3, then rotate. Don't pay attention to the direction of the tread either because the "directional" function is for water displacement so if the track is dry - the carcass doesn't care what direction they are rotating in.
PRO86 | WTCC | STL
#5024 |
Drives: Track preped NA FRS
Just for some extra info, depending on the setup and the driver, you might need way more than past 3.5 degrees of camber up front. The reason you see so many people at around that is usually because their cars are double duty (try to daily a car at 5 degrees) or because their are limited by the setup (camber plates only get you so far). Mcpherson struts like a lot of camber. Also, equal wear does not mean fastest times, you sometimes need to sacrifice the wear and life of the tire to get the best results. For those competing, it matters.
All that to say, the sweet spot for 100-200TW tires (semi slicks or sticky street) and moderate aero (splitter, vents and wing) is in the 4 to 5 region, provided the driver can extract everything out of the car. |
#5025 |
Are you managing your PSI when hot? Excess wear in the middle means they are over inflated?(not 100% sure on this)
#5026 |
Yeah I hate to admit it, but I pulled a typical rookie move and forgot to take hot pressures. I was at 28psi cool, but I completely forgot to grab pressures after I came off the track.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
