Old 07-22-2021, 01:51 PM   #295
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by racingfool View Post
What conditions/surface do BFGs like?
Originally Posted by steverife View Post
In a different car (ES MR2 Spyder) a few years back, I tested Bridgestones vs BFGs at Lincoln and a low grip local sealed asphalt site. Bracketed ABA testing, both tires in prime condition (sticker BFG's and about 20 runs on Bridgestones) and took enough runs that consistency wasn't an issue. Basically ran the same times on both tires at both sites. I liked the car a lot more on the BFG's and they paid better contingency, so that is the route I took.
Neither tire can hold a candle to the Yoks.
Pretty much what he's saying but the heat tolerance on BFGs is significantly better. Especially if you are dual driving. Between the Bridgestones and BFGs you will likely never overheat your BFGs with a co-driver but with Bridgestones you can. The BFGs also recover better if you exceed your maximum cornering grip. They're more sluggish on turn-in (they are wider ever so slightly too) but offer better feedback to the driver in sweepers.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
racingfool (07-22-2021)
Old 07-24-2021, 06:10 PM   #296
3k1n
3k1n's Avatar
Drives: 2017 BRZ limited PP WRC Blue
Curious about this, for the guys that are running -4 degrees of negative camber or more that do occasionally take their cars to the track. Has that much negative camber, negatively impacted braking performance ?
3k1n is offline   Reply With Quote
Old 07-26-2021, 12:02 PM   #297
M0nk3y
I'm at -4.2 of camber. No issues on track
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
3k1n (07-28-2021)
Old 07-27-2021, 11:02 AM   #298
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I'm at -4 degrees. In the bit of data I've looked at there's no noticeable braking distance difference between my current -4 and last years -3.2 degrees.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
3k1n (07-28-2021)
Old 08-04-2021, 12:31 AM   #299
ka-t_240
For those with ao52, has anyone flipped them on rims? I am used to doing this on many other tires, but haven't seen anything mentioned about this on the ao52.
ka-t_240 is offline   Reply With Quote
Old 08-04-2021, 01:41 PM   #300
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
My Yokohamas are wearing evenly.... amazingly so really. Haven't considered flipping because there's nothing to address on mine ~50% in.
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 08-04-2021, 01:51 PM   #301
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
The amount of camber you should be running for an STX build will yield pretty even wear for A052s. My last set wore even all the way to nearly bald at ~130 runs.
Breezio is offline   Reply With Quote
Old 08-04-2021, 02:22 PM   #302
steverife
Same. My first set is around 160 runs. Flipping never crossed my mind.
steverife is offline   Reply With Quote
Old 08-04-2021, 06:49 PM   #303
Locust
Custom User Title
Locust's Avatar
I flipped a set last year and there was no noticeable change in performance one way or the other. Not going to bother flipping them ever again.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 08-05-2021, 12:46 PM   #304
Roadphantom
Drives: FR-S - STX
Did anyone take tire temperatures readings of the Inner-Mid-Outer edges of the A052? What camber and psi do you run them at?
Roadphantom is offline   Reply With Quote
Old 08-09-2021, 12:06 PM   #305
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
In case anyone wanted some data on Nankangs, mine have 66 2-driver hot summer runs with all but 10 of those on concrete and they're looking pretty done for.
I'm going to try and squeeze another 10 runs out of them next week, but useful quality runs out of them were gone by about run 55 I think.
Served their purpose as a good-stop gap to save the Yoko's for nats but I think Falkens will be my answer for local events the rest of the year.
Kelse92 is offline   Reply With Quote
Old 08-09-2021, 12:34 PM   #306
steverife
Old 08-10-2021, 09:52 AM   #307
Breezio
Breezio's Avatar
lack of tread? heat cycled? what exactly is the problem.
I'm 52 runs on my Nankangs and they are performing fantastic. Still have tons of tread left.
Old 08-10-2021, 10:18 AM   #308
Kelse92
At the track
Lack of tread. They could handle a few more heat cycles but they're looking pretty close to slicks at this point.
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
