Old 08-04-2021, 11:14 AM   #379
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
You can also get a custom tune from OFT. Its a few rounds of data logging and sending files but it works well.
https://www.openflashtablet.com/shop/custom-e-tuning/
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 08-04-2021, 11:30 AM   #380
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Originally Posted by jflogerzi View Post
Yes. It was using E50
From Delicious Tuning? Sorry if you already said somewhere.
Cephas is offline   Reply With Quote
Old 08-04-2021, 11:31 AM   #381
jflogerzi
jflogerzi's Avatar
Zach at CSG
2013 Series 10 FRS #553
Old 08-04-2021, 03:16 PM   #382
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
So today was the day. Sadly the old girl's motor is seasoned and is down a bit on power. CSG uses a hub dyno similar to mustang number. I forgot to grab a screen shot that I could see but here where the final numbers:
170WHP Peak
152WTQ Peak
Gained 12-15WHP vs stock car through the entire rev range and peak up to almost 25WHP vs stock. TQ dip is 95% gone with E50 and E20(tuned like 91) its greatly reduced and shifted further in the rev band.
Talking with Zach he was happy with car considering the following:
-Car at the top end was losing about a 1LB of vacuum (could have been caused by Dyno Airflow vs real world)
-Car has stock FP with secondary CAT
-Engine has 83K miles on it
-DI have never been serviced. (he mentioned this could add back 5-10WHP)
-Fairly hot temps (mid 80s to low 90s when we were done)
So all in all compared to the e-tune before power is better but its the smoothness that is much improved. Throttle response also feels better. So with Ace or JDL 4-2-1 dyno tune seems worth it right off the bat if available.
On a Side Note on a dyno jet numbers would between
185-190WHP
162WTQ
Any comparison against the ACE?
Mike_ZN6 is offline   Reply With Quote
Old 08-04-2021, 03:23 PM   #383
jflogerzi
jflogerzi's Avatar
Sadly he did not have any onhand to compare. I tried probing him for number and he would not give sadly.
Old 08-04-2021, 05:02 PM   #384
Mike_ZN6
Mike_ZN6's Avatar
I honestly think CSG does not want a direct comparison between these two headers.
The Following 3 Users Say Thank You to Mike_ZN6 For This Useful Post:
DocWalt (02-22-2022), Goingnowherefast (08-04-2021), Hades (08-06-2021)
Old 08-04-2021, 05:07 PM   #385
jflogerzi
jflogerzi's Avatar
You could be right. Honestly can't go wrong with either imo and JDL is cheaper so...
Old 08-04-2021, 05:09 PM   #386
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
I suspect the two will perform the same or at least within the noise floor of the data. In which case the question is, why would someone pay an extra ~$1,000 for a similarly performing header which basically requires you to upgrade engine mounts and has a history of cracked welds? That's a good question..
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following 3 Users Say Thank You to Goingnowherefast For This Useful Post:
Hades (08-06-2021), Mike_ZN6 (08-04-2021), PulsarBeeerz (08-06-2021)
Old 08-04-2021, 06:43 PM   #387
jflogerzi
jflogerzi's Avatar
Logic can escape ppl... but just be thankful we have options and JDL produced a really solid Header. Look at the weld quality on this overpipe cause I left it raw.
The Following User Says Thank You to jflogerzi For This Useful Post:
Stonehorsw (08-04-2021)
Old 08-06-2021, 11:08 PM   #388
Hades
Hades's Avatar
Drives: 2013 Scion FRS
The fact CSG hasn't released a dyno comparing JDL EL 4-2-1 vs. Ace 350 speaks for itself IMO. They seem to have a dyno comparing every other alternative header. Pretty sure if/when we get an independent dyno this JDL EL will be at least as good as or even better than the ace (maybe with a bit less midrange from what I've eyeballed in the dyno graphs).
Hades is offline   Reply With Quote
The Following User Says Thank You to Hades For This Useful Post:
Goingnowherefast (08-07-2021)
Old 08-09-2021, 06:04 AM   #389
J95
J95's Avatar
So guys I have already my headers ready to mount, and I decided to order an OFT. But it will take time to be delivered to Europe...
So I´m wondering if mounting my headers before receiving the OFT would be any perjudicial to the engine... I have a holidays trip in between (a bit less than 1k miles), and I´m looking forward to mount it already What do you think?
J95 is offline   Reply With Quote
Old 08-09-2021, 08:27 AM   #390
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
It is not advisable to install headers without a tune. May be okay, may be not. I wouldn't take that risk.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
J95 (08-09-2021)
Old 08-10-2021, 09:19 AM   #391
steverife
Drives: 2016 Scion FRS
I ordered STi motor and transmission mounts from RHDJapan on July 12th and they showed up today. So that makes it 9 days total shipped via DHL from Japan. RHDJapan had the best price, too.
Ordered the motor mounts about 8 days ago and hadn't heard anything, so I started to get nervous.
But I woke up to a tracking number today. Supposed to arrive Friday, so that'd put me at the 11'ish day mark.
Thanks for the link.
steverife is offline   Reply With Quote
The Following 2 Users Say Thank You to steverife For This Useful Post:
Mike_ZN6 (08-10-2021), Thefalls (08-10-2021)
Old 08-17-2021, 09:45 AM   #392
Mike_ZN6
Mike_ZN6's Avatar
I got the STi motor and transmission mounts installed last week. The JDL overpipe is still making contact with the front subframe on the passenger side. The banging is not as loud, but it is definitely still happening.
Here is the point where it is making contact:
I am not sure what to try next. It seems no one else with this header and overpipe has encountered this issue. Maybe I could try stiffer exhaust hangers? I am not sure if this would help though, there is very little clearance between the overpipe and the subframe.
Would you guys contact JDL? I am concerned I may have either a header or overpipe with defective fitment.
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
