Old 07-13-2021, 03:38 PM   #351
jflogerzi
jflogerzi's Avatar
If you can return I would. If there desgin is still the same it's pretty damn old. Much better UEL designs than borla
2013 Series 10 FRS #553
Old 07-13-2021, 04:59 PM   #352
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Originally Posted by Qwimby1 View Post
WiSh I'd known about this before I ordered a Borla which is enroute now.
2nd that on sending it back!
Mike_ZN6 is offline   Reply With Quote
Old 07-21-2021, 06:19 PM   #353
Mike_ZN6
Mike_ZN6's Avatar
Originally Posted by steverife View Post
Good luck getting the STi mounts. And if you find 2 sets, let me know!
I haven't noticed the issue with the subframe and I'm on stock mounts launch the car hard for autocross. My concern when I put the header onto the car is that there is only maybe 2 or 3 mm between the tubes and the radiator support. I was worried about melting my fans, but it hasn't proved to be an issue so far.
I ordered STi motor and transmission mounts from RHDJapan on July 12th and they showed up today. So that makes it 9 days total shipped via DHL from Japan. RHDJapan had the best price, too.
The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post:
steverife (07-21-2021), Thefalls (07-27-2021)
Old 07-21-2021, 06:39 PM   #354
jflogerzi
jflogerzi's Avatar
Can you send me the link to them?
Old 07-21-2021, 06:53 PM   #355
Mike_ZN6
Mike_ZN6's Avatar
Here you go:
https://www.rhdjapan.com/sti-reinfor...right-zc6.html
https://www.rhdjapan.com/sti-reinfor...-left-zc6.html
https://www.rhdjapan.com/sti-reinfor...mount-zc6.html
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Old 07-22-2021, 12:32 PM   #356
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
My JDL 4-2-1 Headers showed up today. I have the gaskets and everything needed. Gameplan is to do the following (unfortunately I think I have to wait until next year to get back to back dyno'd):
1. On the same day, when temps have stabilized, run 2x back to back vdyno's in multiple directions w/ Tomei UEL Header + Delicious Tomei UEL Tune and save the data log
2. Using AIM solo/Vbox Sport run some acceleration runs w/ Tomei UEL Header
3. Swap to JDL 4-2-1 EL Header and load Delicious 4-2-1 EL Tune
4. Run 2x back to back vdyno's in multiple directions w/ JDL 4-2-1 EL Header and save data log
5. Using AIM solo/Vbox Sport run some acceleration runs w/ JDL 4-2-1 EL Header
So hopefully this will get us an indication of potential power gains/losses, an insight into the data as far as datalogs go, and some real world acceleration to back up any numbers. The tests will be done on the same day, within a few hours of each other on the same tank of gas. Also for those judging the consistency of vdyno's, I just want to say when they are done right they can be ultra consistent and accurate. Like most things, the output is only as good as your input and most people do it wrong imho. Here's an example of two runs, in the opposite direction. Clearly, they can be repeatable when done right.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following 4 Users Say Thank You to Goingnowherefast For This Useful Post:
J95 (07-22-2021), jflogerzi (07-27-2021), Mike_ZN6 (07-22-2021), Turdinator (07-26-2021)
Old 07-22-2021, 03:22 PM   #357
Mike_ZN6
Mike_ZN6's Avatar
@justinco did a direct comparison with the Revworks UEL and the ACE 350 a while back: https://www.ft86club.com/forums/showthread.php?t=125559
I'm interested to see the real world acceleration difference between the Tomei UEL and the JDL 4-2-1.
Old 07-27-2021, 01:04 AM   #358
jflogerzi
jflogerzi's Avatar
I week away from Dyno tune day with Zach at CSG
Old 07-27-2021, 03:38 AM   #359
Thefalls
Thefalls's Avatar
Drives: Corolla GT
You fitted them already?
It a very good upgrade.
After fitting the trans mount ( the other two were fitted earlier on ) I noticed a slight vibration in the steering wheel at stock idle.
But overall very satisfied, the car is a daily anyways .
Thefalls is offline   Reply With Quote
Old 07-27-2021, 09:59 AM   #360
Mike_ZN6
Mike_ZN6's Avatar
Not yet, hopefully within the next 2 weeks I should be able to get them on.
I already have the Whiteline KDT926 transmission mount insert installed and I did not notice much increase in NVH. The STi unit will be replacing the stock mount and the Whiteline insert. My car is a daily as well, I am hoping the vibration from the STi transmission mount is not too bad.
Did you notice any increase in NVH from just the STi engine mounts?
Old 07-27-2021, 03:42 PM   #361
gpvecchi
gpvecchi's Avatar
Just added noise from the gearbox mount, no vibrations.
The Following User Says Thank You to gpvecchi For This Useful Post:
Mike_ZN6 (07-27-2021)
Old 07-28-2021, 09:59 AM   #362
Goingnowherefast
Out with the old, in with the new.
Initial thoughts before we've completed the tune:
The car runs and drives much smoother with the EL headers. Idle quality is up and NVH is down across the board. At speed, it basically sounds like a combination of a generic Honda + rotary (in a weird way). I'll admit, it's lost some of the sound character of the UEL headers. My setup also has a tiny bit of rasp around 4,250 rpm. We're still tuning it so I haven't been able to take any vdynos but I suspect it picked up some power and area under the curve.
The Following 2 Users Say Thank You to Goingnowherefast For This Useful Post:
J95 (07-28-2021), jflogerzi (08-03-2021)
Old 07-30-2021, 03:40 AM   #363
Thefalls
Thefalls's Avatar
Drives: Corolla GT
From just the STI engine mounts there were no NVH at all. It was a very good feeling while accelerating.
When I added the gearbox mount after around a month or so then i noticed a bit of vibration in the steering wheel at idle only. Nothing to spoil the fun but just an observation.
Mind that I don't have any other uprated bushing on the car yet.
There is a very solid feeling after you install all the mounts and they do settle down after some driving. Lets say around 2-3k kms.
For a daily setup you can't go wrong with these mounts. Well worth the purchase.
The Following User Says Thank You to Thefalls For This Useful Post:
Mike_ZN6 (07-30-2021)
Old 07-30-2021, 04:10 AM   #364
J95
J95's Avatar
Nice! Thanks for the comments. I will receive mine in 2 weeks
What about the o2 sensor? I guess you do have the error light until you tune it. Is there any way to get rid of it until the tune comes? For me it will take a while...
J95 is offline   Reply With Quote
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
