Old 08-02-2021, 06:40 PM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
secondary fuel pump on a manual switch that sits on the passenger side, dumping into main pump cup.
Fuel pumps are cheap, and burning one out once a year from starvation is a relatively small price for going faster. It's less than the cost of a single tire.
How difficult is that to implement? Has anyone documented this? If I wing it I *will* f it up :O
Will it fit under stock seats? Is street car...
Old 08-02-2021, 07:23 PM   #30
CSG Mike
CSG Mike's Avatar
Completely in-tank.
Documented.... not really. Been done? Absolutely.
Old 08-02-2021, 08:16 PM   #31
ZDan
ZDan's Avatar
Drives: '23 BRZ
Completely in-tank.
Hhrrmm...
Do you have any thoughts regarding my getting fuel starvation at more than 7/8 tank after a long straight followed by a 90+ degree *right*-hander at Thompson?
Old 08-03-2021, 03:59 AM   #32
CSG Mike
CSG Mike's Avatar
Hhrrmm...
That shouldn't be happening. Investigate the fuel pressure drop.
ZDan (08-03-2021)
Old 08-03-2021, 10:39 AM   #33
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think I might go in and inspect my Verus fuel door installation. I'll probably remove it, at *best* it didn't improve things at all between New Hampshire and Palmer1. At *worst* that little 3d-printed plastic door (NOT the advertised and illustrated aluminum door with steel pins!) is f-ing things up due to either being broken or possibly too lightweight to work properly.
UPDATE: the part is indeed cnc'd aluminum, NOT 3d-printed plastic! So lightweight (due to being massively hogged-out) and painted shiny black plastic with integral pins rather than previous version (?) pressed steel pin, really gave me the impression of being plastic when I installed it! Just removed it and can confirm it's aluminum
Old 08-03-2021, 10:55 AM   #34
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Wait what? I'm 99.9% sure mine was CNC'd aluminum with steel pins. Purchased within the last 3 months.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 08-03-2021, 11:28 AM   #35
ZDan
ZDan's Avatar
Drives: '23 BRZ
They changed over at some point. Here's the plastic part:
The density of PLA plastic is less than half that of aluminum, and it's only 65% more dense than gasoline. Pretty sure I'm gonna remove it and ask for my $$ back.
They show the anodized aluminum one on the Verus website and here's their description:
SPECIFICATIONS
CNC Machined
6061-T6 Aluminum Construction
Anodized Bright-Dip Black
Viton O-Ring for Ethanol and Gasoline Compatibility
Yeah, that is not what I got...
Old 08-05-2021, 08:50 AM   #36
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
Dan, you got hosed! I would definitely get my money back, that is way too much money for a PLA printed part!
Talked to some of the GTA guys and they said only starvation at half, and one of them tried the fuel door and it didn't fix it either.
TunaNoCrust is offline   Reply With Quote
The Following User Says Thank You to TunaNoCrust For This Useful Post:
ZDan (08-05-2021)
Old 08-05-2021, 10:52 AM   #37
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'd be fine with it if it *worked*. But no way I would have even bothered with it, whatever the price, had I known it was plastic.
PLA is only 1.65x denser/heavier than gasoline.
Aluminum is 3.6x denser/heavier than gasoline.
Stainless steel is ~3x denser/heavier than aluminum and IMO would have been the way to go...
Plastic is a stupid material choice for this application for anything other than making the part cheap.
I think I have an aluminum one on the way to me now. On the fence whether I'll install that when I remove the plastic one or just revert to stock with no door.
Old 08-05-2021, 11:39 AM   #38
ML
ML's Avatar
Drives: 13 White MT FR-S
Did you replace the black rubber seal(one time use part) and the green ring? And did you put it together properly? I have yet to meet a twin "expert" who has done it correctly.
You have to ensure the black seal lip isn't hanging over the tank lip before tighting correct? I had a bad seal and replaced it and noticed this as I was putting the lock nut back on. If thats not what you mean can you expand on your comment?
Old 08-05-2021, 11:43 AM   #39
ML
ML's Avatar
Completely in-tank.
it has been documented pretty well by the 350/370z community. Same principal.
Old 08-05-2021, 01:28 PM   #40
norcalpb
norcalpb's Avatar
SPECIFICATIONS
CNC Machined
Please keep us updated on what they say! Verus is always revising their parts, but this is the first time I’ve seen them changed for the worse…thank you for doing the math on the density of the part materials.
Old 08-06-2021, 08:12 AM   #41
TunaNoCrust
And that is assuming they are using 100% infill...and if they are using an FDM type printer, the part is not liquid tight anyways.
The GTA guy said his door was plastic as well.
Old 08-06-2021, 10:57 AM   #42
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@ZDan, has your car by chance been included in the new fuel pump recall? Just a thought.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 13 10-09-2025 02:56 PM
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-28-2018 11:47 PM
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 03:22 PM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 11:19 AM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
