Software Tuning Discuss all software tuning topics. |
#99 | |
Drives: JRSC BRZ SOLD
I have a copy of the OP's dyno but I don't want to post it if he had reasons for its removal. TBH they look the same... 4-5whp difference peak but that could easily be down to wheel/tires or a catted midpipe. But, yah they look the same, same shop dyno, same tuner, near identical base lines, both on E85 (~E50), same loads, both used STD correction, both used 5th gear. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Mike_ZN6 (07-29-2021) |
#100 |
Drives: 2013 Scion FRS
Interesting - I wonder why he removed it. Which header came out with more HP? I've heard reports of the JDL pulling harder up top, but hard to know for sure as both headers look quality. Really wish there was a more direct comparison.
The Following User Says Thank You to Hades For This Useful Post: | PandaBRZ (07-29-2021) |
#101 |
I got my JDL EL 4-2-1 mounted and I tuned with OFT Stage 2+. I definitely notice gains in power around >5k rpm. Not much gains in torque dip though.
Is there any OFT tune more convenient than the stage 2+? |
#102 |
Drives: 2014 GT86
OFT OTS tunes are originally mostly made for their own OFT header (which is UEL). JDL EL one, especially due it being longtube header, may net limited gains with such generic tune made for different header. I have suspicions that you'd be better off paying Steve99 or wayne to fine-tune your ecu tune specific to your header, or go Ecutek and some good tuning-shop, eg. Delicious or CSG.
The Following User Says Thank You to churchx For This Useful Post: | J95 (08-28-2021) |
#103 |
Drives: Subaru BRZ 2016
#104 |
JDL 4-2-1 Header
JDL Ultra Quiet Catted FP/OP Perrin 2.5 Resonated Exhaust E85 - PTuning FF Kit. E76 at time of dyno pulls CSG Tune by Zach ![]()
Kyle H. - #89 STX
#106 | |
2013 Series 10 FRS #553
#107 |
Drives: 2013 Toyota GT86
Hi Guys, new here but have recently installed the JDL 4-2-1 headers onto my 86. I took it to a local ecutek tuner here and had a custom dyno tune as well as a flex fuel kit installed. The car feels really strong in the top end but it still feels like the mid range is lacking a bit (2.5k to 3.2k RPM feels sluggish, unsure if others have this experience on these headers/tune)
Looking through the forums here it looks like people have made pretty good gains in the mid range and eliminated the torque dip almost entirely. Would appreciate if anyone could shed some light on this, I've attached the results from the dyno but it only shows the power, speed and air to fuel ratio so not sure if that helps but it looks like there is a big dip in the middle which I'm thinking could be the torque dip still remaining. Thanks! |
The Following User Says Thank You to Miatchimus For This Useful Post: | J95 (11-09-2021) |
#108 |
Looks pretty flat to me. What does a completely stock car get on that Dyno. Best way to compare
Sent from my Pixel 5a using Tapatalk
#109 |
Drives: brz 2017 hksv2
change tuner.....
#110 | |
Meow
Drives: GT86, Volvo 996
How can you have what's almost a power dip, without a torque dip to match? The torque / power curves you have should be mathematically incompatible. Am I missing something? |
#111 |
Drives: 22 BRZ limited
#112 |
Meow
Oh.
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust | pinski | Software Tuning | 8 | 11-21-2016 11:07 AM |
My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results | JDM-dono | Engine, Exhaust, Transmission | 24 | 05-05-2016 04:54 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
