Old 07-28-2021, 10:58 PM   #15
Turdinator
Señor Member
Turdinator's Avatar
Something to keep in mind, if you are using OFT for tuning a UEL will be better optimized to the preloaded tunes. If you go with an EL 4-2-1 option like the JDL or ACE the cam timing will be out. Drivability and power across the rev range won't be as good as they could be. If you want a tune properly set up for the 4-2-1 style headers you will need to go to a tuner like CSG, Delicious or HRi tuning. HRi may do an OFT tune for those headers but you'd need to check. Delicious and CSG are Ecutek only.
1974 TA22 Celica
2013 86 GT
Old 07-29-2021, 12:25 AM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by ZDan View Post
2017+ factory catted header would be my choice...
I did the same.
Old 07-30-2021, 06:24 PM   #17
Grady
Grady's Avatar
Ok so you have a 2020 so you already have a 2017+ catted stock header. I would not replace it if you want to stay catted. You will see almost 0 gain and possibly get a negative gain. What you want is a good tune for your engine. If you want a good gain from the header you will need to go cat-less.
Old 07-30-2021, 06:31 PM   #18
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
The number one thing I want is a reduction (or preferably elimination) of the torque dip. Added power is the bonus, especially since I'm at 5000 ft plus which means I'm already dealing with about a 15% loss in power versus sea level.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 07-30-2021, 07:13 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So basically any header. Gruppe-S, Tomei, JDL, whatever.
Keep the factory front pipe. Tune. Deal with any emissions ramifications whenever you need to.
Don't bother spending any money on the front pipe.
Old 07-30-2021, 10:05 PM   #20
bucketfoot
bucketfoot's Avatar
So does catted vs non-catted matter much in what I'm looking for?
Old 07-30-2021, 11:15 PM   #21
mav1178
mav1178's Avatar
for purposes of getting rid of your torque dip, no.
for your budget, it's about a $400+ dollar difference.
for tailpipe, neither of them matter if you keep the stock front pipe. your cold starts might smell a bit more but once it's warmed up then it will mostly be the same.
Old 07-31-2021, 07:55 AM   #22
Grady
Grady's Avatar
Tune and E85 will fix that better than a Different header. If you have access to E85. Spend the extra on flex-fuel kit so there is no re-flashing needed if you can not get E85.
Old 07-31-2021, 08:01 AM   #23
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This x1000.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
alphasaur (08-05-2021)
Old 07-31-2021, 10:21 AM   #24
ChRZ
ChRZ's Avatar
Drives: 2017 BRZ SP
HKS makes a catted EL (GT SPEC), JDL does too.
... and that your exhaust hangers on the catback section (5) are either JDM, or any other material that will be thicker than OEM quality....
Hmmm. Interesting. Say more about this?
So thicker hangers insulates more vibration from the rest of the car compared to flimsier ones??
I guess I always assumed "drone" was some resonant sound frequencies, but if this is true then it's also some vibration.
ChRZ is offline   Reply With Quote
Old 07-31-2021, 11:31 AM   #25
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I installed the STI/JDM exhaust hangers on my car with a Yonaka catback. I had not had real problems with droning but the exhaust did rattle and make a racket on start up. The new hangers did quiet the rattling and changed the exhaust sound in the cabin as well. At all road/engine speeds the exhaust sound is more controlled. My car used to drone a wee bit at 2500-3000 rpm (below my highway cruising speed). No more. It's smooth and quiet on maintenance throttle all the time and only becomes audible when you tip in to the throttle.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-31-2021, 02:04 PM   #26
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Correct, you can’t do anything about exterior sound by changing hangers but cabin vibrations can be reduced, which in result can be more pleasant when driving city/highway.
spcmafia is offline   Reply With Quote
Old 07-31-2021, 02:22 PM   #27
Yoshoobaroo
TRACKBREAD
Sound=vibration, they’re one and the same.
Drone is the exhaust pipe literally vibrating like a hitting a ruler cantilevered over a desk. The pipe resonates and you perceive it as sound in the cabin. If the sound is close enough to the resonant frequency of the body, that will vibrate too.
Insulating the exhaust from the body with more compliant hangers helps. Stiffer (thicker) hangers will make it worse.
Old 07-31-2021, 02:57 PM   #28
spcmafia
spcmafia's Avatar
Well technically the JDM Subaru hangers are a thicker version of the US market ones. They greatly reduced cabin resonation for me after installing a louder exhaust.
JDL UEL Catted Header vs FT86 SpeedFactory UEL Catted Header Thomas K BRZ First-Gen (2012+) — General Topics 9 03-08-2021 08:39 AM
JDL UEL Catted Header vs FT86 SpeedFactory UEL Catted Header Thomas K Scion FR-S / Toyota 86 GT86 General Forum 0 03-06-2021 06:58 PM
WTB: OFT V2 and ft86 speedfactory catted header/ or any other catted header Control_Dopamine Want-To-Buy Requests 0 05-14-2020 03:31 PM
FS: P&L catted & coated EL header, Perrin catted front pipe and res 2.5" catback Turbowned Engine, Exhaust, Bolt-Ons 13 08-11-2019 11:54 PM
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? l3ooml3al2al3a Engine, Exhaust, Transmission 12 03-22-2019 10:22 AM
