Old 07-27-2021, 07:53 PM   #1
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Track Heat Management
I have been having an issue this season with heat management and am looking for suggestions.
Car is NA
E85
Header is ceramic coated inside and out. FP/OP is not.
Driveway Labs hood duct
AC Delete
Added Koyorad about a month ago
Last year I was seeing 220-225F max on coolant temps which I was okay with. This year went E85. Since last year I moved my oil cooler to give it cleaner flow but it is center of my radiator right in the opening. My oil temps have been good, about 210-220F, much lower then before. My water temps where hitting 240F at around 85F ambient. Went to a Koyorad, still seeing 230F and sometimes still approaching 240F water temps during longer sessions 80-85F ambient. I am thinking more hood ducting and moving my oil cooler over to behind one of the fog lights. I haven't really heard too many complaints about water temps NA so I am kind of surprised by this. Again, other suggestions welcome.
Old 07-28-2021, 12:22 AM   #2
Do you lose coolant?
Old 07-28-2021, 12:49 AM   #3
DarkSunrise
DarkSunrise's Avatar
Something seems a bit odd about your coolant temps. I’ve logged pretty frequently at the track (93 octane) and the canyons (e85). I think my setups have generally been similar to yours (NA, various catted/uncatted headers, center mount 13 row setrab oil cooler). No hood ducting though.
In the worst conditions, I’ll typically see peaks of 245-247F oil and 210-212F coolant), and I think that’s typically what most frs/brz drivers see (higher oil vs coolant temps). Your temps are the reverse for some reason. What kind of oil cooler do you have? If it’s a massive 19+ row that’s dumping heat into your radiator (especially with the hood ducting), maybe that’s the reason?
Old 07-28-2021, 12:51 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Nope.
Old 07-28-2021, 12:54 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In the worst conditions, I’ll typically see peaks of 245-247F oil and 210-212F coolant), and I think that’s typically what most frs/brz drivers see. Your temps are the reverse for some reason. What kind of oil cooler do you have? If it’s a massive 19+ row that’s dumping heat into your radiator (especially with the hood ducting), maybe that’s the reason?
I used to see oil temps like yours when my oil cooler was mounted to the lower tray. The “chin” of the bumper was masking it so I remounted it to the crash beam in the middle of the opening. It is a Setrab 613 core.
Old 07-28-2021, 01:00 AM   #6
DarkSunrise
Did you have similar coolant temps as mine (210-212F) when your oil cooler was mounted to the lower tray? Or have your coolant temps always been high?
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
slockin (07-29-2021)
Old 07-28-2021, 01:16 AM   #7
Could be the air gap between the rads. Try an experiment. Make a shroud behind the oil cooler to keep the air from cutting up between them. Just some aluminum tape should do the trick.
I should get mine out to that CSCC HPDE in August to really beat the piss out of my setup but I'm already pretty sure the results will be similar to my uphill wide open jaunts. Water below 200F. Oil below 190F.
NoHaveMSG (07-28-2021)
Old 07-28-2021, 01:36 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It would be 210-220 peaking in the mid 220’s before.
Old 07-28-2021, 01:39 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is a good point. I’ll try blocking off the gaps. It isn’t helping I lost some of both my inner fender liners. I am probably venting a good amount of flow out those gaps too.
Old 07-28-2021, 01:54 AM   #10
Oh, yeah! I have all the factory shroud in place.
Old 07-28-2021, 08:01 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you had oil temps <250F and coolant temps <220F before repositioning the oil cooler, I'd just move the oil cooler back where it was and done! Synthetic oil is gonna be fine at WAY higher temps...
Old 07-28-2021, 09:47 AM   #12
DarkSunrise
Yeah that's pretty high for that setup (at least from my experience), by about 10-15*.
If your cooling system is in good shape and fully bled, and shrouding is in place, then ducting sounds like a good idea and replacing those damaged inner fender liners like you mentioned.
2022 BRZ Build
2013 FR-S Build
Old 07-28-2021, 11:49 AM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am rather enjoying the much more stable oil pressures. I will probably shift the oil cooler behind a fog light opening or offset it farther and duct it separately.
ZDan (07-28-2021)
Old 07-28-2021, 11:53 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Are pressures more stable, or just higher in general due to lower temp? My understanding (I haven't logged pressure so I'm going on info from others here) is that the pressure becomes unstable at high rpm due to cavitation rather than from temperature...
Engine Management Q2 Forced Induction 9 12-04-2017 05:37 PM
heat management, CF hood alternative Reaper Forced Induction 70 07-05-2017 01:22 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Top half car covers for cabin heat management on track dp1 Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2014 11:08 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
