Old 07-25-2021, 06:31 AM   #19223
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
My wife has put the keyless fob for our other car through the washing machine 3 times now, and amazingly it still works too!
ACT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to ACT86 For This Useful Post:
BrahmaBull1990 (07-25-2021), dpfarr (07-25-2021), soundman98 (07-25-2021)
Old 07-25-2021, 09:30 AM   #19224
JD001
JD001's Avatar
Drives: Subaru BRZ
What about the fob??
Old 07-25-2021, 11:44 PM   #19225
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Installed the Jackson Racing oil cooler. It works a little too well on the highway, but it's great on the track!
N_Raged is offline   Reply With Quote
The Following 3 Users Say Thank You to N_Raged For This Useful Post:
dpfarr (07-26-2021), norcalpb (07-26-2021), Stonehorsw (07-26-2021)
Old 07-27-2021, 01:39 AM   #19226
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Make a removable cover so it only cools on the track. I did on mine and it runs like standard until it`s uncovered. Apart from a slightly longer oil warm up.
Old 07-27-2021, 01:41 AM   #19227
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Test fitted my Enkei GTC02 18x9+42. Will fit some 255`s on em
The Following 5 Users Say Thank You to gen3v8 For This Useful Post:
ACT86 (07-27-2021), Dzmitry (07-30-2021), soundman98 (07-27-2021), Stonehorsw (07-27-2021), Wally86 (07-27-2021)
Old 07-27-2021, 02:10 AM   #19228
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Wrapped my mirrors today.
Used Vivid Carbon Fiber with texture. Left over from my previous car. Figured I’d use it up before I get some more. I’m not a pro but I’m happy with it for the most part. A few wrinkles but only on the tight corner towards the window. I’ll redo it once I get some more from Amazon. Took a few hours haha. But hey, it beats paying someone to do it! And just in the one for Portland Super Subie Stancewars!
Sur is offline   Reply With Quote
The Following 2 Users Say Thank You to Sur For This Useful Post:
Dadhawk (07-27-2021), soundman98 (07-27-2021)
Old 07-27-2021, 09:41 AM   #19229
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Looks good. Prepare to not be able to turn to full lock without rubbing on the inside of the fender well.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
Old 07-27-2021, 09:54 AM   #19230
yngvarr
Clueless
yngvarr's Avatar
Drives: none
Originally Posted by BrahmaBull1990 View Post
Just watched this whole series (so far). This guys is awesome! He is a complete engine novice and is filming his journey as he rebuilds his motor with an IAG Stage 2 block. Motivation for sure!
Is he a member here?
Thank you for linking this series. Was looking for similar assembly/disassembly videos. This one never came up in the search.
yngvarr is offline   Reply With Quote
The Following 2 Users Say Thank You to yngvarr For This Useful Post:
BrahmaBull1990 (07-27-2021), J95 (08-04-2021)
Old 07-27-2021, 10:35 AM   #19231
N_Raged
Yea my friend at autocross suggested that. I'll block the entire thing in the winter, and maybe make a cover with a smaller opening for the summer based on my needs.
Old 07-27-2021, 11:46 AM   #19232
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Will 255s rub on those wheel specs?
(I'm assuming they need small spacers then?)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-27-2021, 01:45 PM   #19233
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Completed my first SCCA TT event. I ran one before but the car didn't survive. Learned a lot. Ended up running Max3 since there where no other cars in Max4 and got 3rd, though a long way back from 1st and 2nd in class, a Cayman and a turbo SW20. Had a lot of fun and was going back and forth with an M3 in my class all weekend until his SMG pump failed. Still having cooling issues even with Koyorad. Oil temps look okay so
The Following 8 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (08-03-2021), DarkSunrise (08-02-2021), Dzmitry (07-30-2021), gen3v8 (07-27-2021), LancePower (07-27-2021), norcalpb (07-27-2021), soundman98 (07-27-2021), Stonehorsw (07-27-2021)
Old 07-27-2021, 03:56 PM   #19234
norcalpb
norcalpb's Avatar
Car looks great, loving that driveway labs hood vent.
What are those little silver things on top of your splitter?
The Following User Says Thank You to norcalpb For This Useful Post:
NoHaveMSG (07-27-2021)
Old 07-27-2021, 04:20 PM   #19235
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks.
I had an off last year and messed up the splitter. So I flipped it over and drilled out the brace in the front to take more fasteners. I also added another brace in the rear to support it better. The silver things are the bolt heads. This one is on it's last legs, I will probably build something much sturdier for next year this winter.
Old 07-27-2021, 07:17 PM   #19236
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Looks great! I've been preparing to wrap my other car and watching videos to learn before I dive in. There is actually a tool to assist with stretching over the mirror. Quite pricey for one use. I wouldn't have even noticed it you didn't mention it.
2020BRZtS is offline   Reply With Quote
