Old 08-30-2019, 03:12 PM   #1
GrabTheWheel
Drives: 16' BRZ
ARP wheel studs 1.95 UHL?
Has anyone installed these ARP wheel studs? I know I don't want the extended ones because I'm not running a spacer; so was thinking the stock length ARP stud then I noticed they have this 3rd option that switches thread from 12x1.25 to 12x1.5 and they are just slightly longer than stock. They will be paired with 949 racing lugnuts. So which should I get stock length with 12x1.25 thread or the slightly longer 1.95 UHL ones with 12x1.5 thread?
GrabTheWheel is offline   Reply With Quote
Old 08-30-2019, 04:56 PM   #2
wparsons
wparsons's Avatar
Why bother getting the slightly longer ones? 0.2" is 5mm, so if you don't need the extra length you'd be fine with the stock length ones.
It's interesting that there's at least 4 options for our cars now... the original ones were these ones: https://arp-bolts.com/kits/arpkit-de...hp?RecordID=76 and aren't even listed under the FRS anymore.
I wonder if the slightly shorter ones that are listed now (100-7729) are short enough to be pulled into the rear hubs without removing it from the car. The 3" ones definitely won't go in, but maybe 0.5" less makes it fit.
flickr
Old 08-30-2019, 05:20 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Only ask in one place.
Old 08-30-2019, 08:30 PM   #4
Impureclient
Drives: 2015 FR-S
That is correct, I did it last year with the 2.535" ones(100-7729): https://www.ft86club.com/forums/showthread.php?t=128354.
Old 07-22-2021, 04:49 PM   #5
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Noticed they now have 1.95UHL studs in 12x1.25. The only difference appears to be that the 1.95's have a 0.2 cone on top to help cross threading issues vs the standard 1.75 ARP replacement ones.
Can anyone confirm if the 1.95 ones will slide in the back without removing the hub like you need to do for typical extended studs that are 2.5 inches+?
cmiovino is offline   Reply With Quote
Old 07-27-2021, 08:50 AM   #6
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If Amazon reviews are to be believed.
These are the absolute longest studs that can be installed in the rear hubs of the BRZ and FRS WITHOUT removing the hub from the car. If they were even 1mm linger, the House b would have to come off. There is just enough space at the very bottom, to wiggle the new stud in after the old it hit out. The caliper and rotor need to come off, but nothing else. Great design.
Old 07-27-2021, 09:31 AM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
As referenced via link posted above you can install 2.5" studs on the rear hubs without removing them. 1.95" are the longest as a straight install.
I used a Dremel to cut off the nipple at the end and was able to wiggle them in by rotating the hub and angle them in.
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 10:50 AM
In Need of Wheel Studs Hurby Southern California 1 10-03-2016 01:25 AM
ARP Wheel Studs FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-09-2015 06:50 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 03:22 PM
