Old 07-21-2021, 08:22 AM   #1
J95
J95's Avatar
How can I mount this oil cooler?
Hello! I need some advise about how to install my oil cooler kit. I have this one:
https://avoturbo.com/brz-frs-86-fa20...il-cooler-kit/
But I am missing some parts, the steel brackets, the rubber isolator and the air duct. Without the steel brackets I can not mount it where it should be mounted. Here some pics about its theoretic position, see attached (red car)
I thought about attaching it to the plastic bumper like in the picture of the blue car. But I don´t know how reliable it is... and also I guess the hoses are too long for that location and maybe they would not fit.
I need some ideas... What would you do, where should I mount the radiator?
J95 is offline   Reply With Quote
Old 07-21-2021, 08:26 AM   #2
Ashikabi
Ashikabi's Avatar
Go to hardware store and get some aluminum flat. Make brackets to mount to crash bar.
Mount where hoses allow since you can't change that length
Sent from my ONEPLUS A5010 using Tapatalk
Old 07-21-2021, 02:48 PM   #3
norcalpb
norcalpb's Avatar
I have mine mounted to the plastic tray like in the blue car’s picture, with racer X cooler mounts. If I didn’t have my Verus front splitter, I’d be pretty worried about it getting smashed so ideally you’d want it mounted to your crash bar (but it would suck if your lower tray got smashed up against the cooler).
First you want to find out the manufacturer of the oil cooler itself, and find kits from other companies that use that same cooler and email them asking if you can buy their mounts. They should be pretty cheap unless you are getting Perrin mounts which are super expensive for what they are.
Old 07-28-2021, 09:17 AM   #4
J95
J95's Avatar
Thank you both!
Apparently there are no manufacturers in Europe that make kits for the radiator in a similar position. Maybe I will have to buy different aluminum parts and keep trying until I get a confortable position somewhere in the right flank
Question about low mount oil cooler askho Engine, Exhaust, Transmission 8 06-25-2020 07:25 PM
Where to mount thermostat for AT cooler Tristor Engine, Exhaust, Transmission 14 09-04-2018 06:10 PM
Battle Aero Chassis Mount & Trunk Mount Kits For FRS / BRZ / GT86!! Rev Motion Exterior Parts - The Rest 6 06-28-2016 09:26 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
