Old 07-20-2021, 05:45 AM   #1
FooisM
Drives: 2015 BRZ
Non steering wheel controller for HU
Hi all,
2015 brz so no controllers on this models steering wheel.
My HU (DDX917WS) doesn't have a physical knob for volume which is a pain.
I'm looking for solutions to be able to change tracks as well as volume up/down.
I know there is an option to get a 2019 wheel + clockspring, but that is way too much effort for reward.
There are some BT controllers, do these work with any HU?
What have some other people on here done?
FooisM is offline   Reply With Quote
Old 07-20-2021, 09:27 AM   #2
Compelica
Compelica's Avatar
Drives: 86 GT
Did this for mine - running a Kenwood DDX918WS. Mine's a China set wired to the steering wheel inputs of the HU, with the buttons operating wirelessly.
https://www.ft86club.com/forums/show...ostcount=21688
Compelica is offline   Reply With Quote
Old 07-20-2021, 10:26 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by FooisM View Post
Hi all,
Doing a quick Google search on the model number you provided, I see that your head unit is a Kenwood product. Finding the installation and operation manual, for your unit, I see that it has an optional infrared remote available. It also has a Light Blue with Yellow stripe wire that is used for steering wheel controls. Getting the steering wheel controls working will be custom project with your car, you don't HAVE to mount your control on the steering wheel, though. You might try a location on the center console, and you might even be able to find a control with an actual knob to turn.
Some Bluetooth controls can control volume, but most only control the track functions.
Personally, I use an infrared remote that I can strap to the emergency brake lever to control my Pioneer.
Edit: As I look closer at the installation manual for your head unit (which covers several different models), I now see that your particular model DOES NOT have the light blue and yellow wire, so wiring in a remote like @Compelica did is not an option for you. If I were you however, I would pull the head unit out and physically look for that wire, you never know what the manufacturers will do from country to country.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 07-20-2021, 10:50 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
That looks nice.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Compelica (07-20-2021)
Old 07-20-2021, 07:22 PM   #5
FooisM
Drives: 2015 BRZ
Yeah this is exactly what I was thinking, a volume control here and move the seat warmers somewhere else. perfect.
Would you happen to remember what controllers you bought?
I really want a wired set rather than a BT set.
Old 07-20-2021, 09:03 PM   #6
Compelica
Compelica's Avatar
Drives: 86 GT
it's this one.
https://a.aliexpress.com/_mNKzF99
Old 07-20-2021, 10:17 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Your head unit must have either that light blue/yellow wire or you'll have to use the jack on the back for you to hardwire a remote to it. Check for one of those two options first before ordering a control for it. You'll have to program the head unit to learn each button.
Old 07-20-2021, 11:06 PM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by FR-S2GT86 View Post
Your head unit MUST HAVE that light blue/yellow wire for you to hardwire a remote to it. Check for that wire first before ordering a control for it.
Apparently it's there listed in the manual, where for the DDX917WS it is listed as a separate accessory. WS models uses a 3.5mm jack to a proprietary 26 pin Toyota connector, as for the other models intended for other regions it is via the single harness.
The Following User Says Thank You to Compelica For This Useful Post:
FR-S2GT86 (07-21-2021)
Old 07-21-2021, 01:26 AM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You're right. I stand corrected. I didn't see that earlier when I replied. Some of the models use the single wire and some use the jack and plug with three conductors. It will still be a completely custom install, like yours.
Retaining steering wheel controls w/ aftermarket steering wheel on +17 BRZ/86 DDavid Electronics | Audio | NAV | Infotainment 8 04-22-2021 05:37 AM
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-06-2017 11:20 PM
My steering wheel is stuck: Cusco steering wheel norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 4 01-01-2017 04:48 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 06:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
