Old 07-18-2021, 12:39 PM   #1
Cae2444
Drives: 2015 FR-s
FRS won’t start, already tried new battery.
(See below Video)
Automatic 2015 FRS engine won’t start at all. I tried a brand new battery and it did not resolve the issue. When turning the key entirely, there’s no noise and no clicking. The dashboard lights up, the radio/stereo system does not come on. The key still locks/unlocks, though none of the power window or power lock buttons inside the car work. Will check starter later today, though While initially trouble shooting, we actually managed to get the car to start after fiddling around with locking and unlocking the car via the key. Possibly something with the immobilizer? Either way after getting it to start that one time, we could not get it to come back on again. Let me know if you guys have any ideas.
https://storage.cloudconvert.com/tas...pe=video%2Fmp4
Cae2444 is offline   Reply With Quote
Old 07-18-2021, 03:24 PM   #2
Grady
Grady's Avatar
Starter, Start relay, Neutral/Park switch. Do you have a VOM and know basic electrical?
Old 07-18-2021, 08:33 PM   #3
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Neutral/park switch always seems to be an issue with these cars. The switch is really hard to find because it sits way up behind the clutch pedal or brake pedal depending on whether you're automatic or manual. But I would start with that you should be able to lay on your back under the steering wheel console and look up to see if you can see the switch sitting behind the pedal when you engage the brake to start your car that switch pin gets pressed in and allows you to turn the car on. Try and press the switch with your finger with out engaging the brake, and have someone press the push start or turn the key for you. If you can get it to turn on like that then that's your issue my fix was simply to put thick magnetic tape on the little plate that pushes the pin so now little effort engaging the clutch pushes the pin in to turn it on.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 07-18-2021, 08:46 PM   #4
Automatic also has a switch in the shifter mech
Old 07-18-2021, 09:06 PM   #5
BlOody_BoOger
Here a general image of what your looking for it's not exact the same but the location is similar
Old 07-19-2021, 08:38 PM   #6
Cae2444
Drives: 2015 FR-s
Looked and looked, wasn’t able to find this button.
If it matters, I can’t put put the car into neutral or anything either.
The security light stops flashing when key is inserted, so I guess its not the immobilizer?
Old 07-19-2021, 09:25 PM   #7
Cae2444
Drives: 2015 FR-s
Additional details-
Headlights turn on just fine.
Stereo system does not come on at all.
Old 07-19-2021, 09:29 PM   #8
stacyu18
Drives: 2014 subaru brz
look for the key symbol on the dash when you try to start the car look at what colors it is if its red or yellow change the battery in the key fob i had this problem once also
stacyu18 is offline   Reply With Quote
Old 07-19-2021, 09:48 PM   #9
Cae2444
Drives: 2015 FR-s
The dash key symbol is flashing red. Now that I think about it I swear I remember it flashing amber/yellow before. I’ve seen mention it flashing “green” but it never flashed green in the past, only amber/yellow like normal.. The light does stop though when key is in ignition.
Old 07-19-2021, 10:10 PM   #10
stacyu18
change the key fob battery bet that will solve your problems
Old 07-20-2021, 03:09 PM   #11
Cae2444
Drives: 2015 FR-s
Changed the key battery!!!
Aaaaaaand.
Still dead 💀 Probably just going to have it towed at this point. How’s that work if I can’t change the car into neutral and it’s at the top of a parking garage lol
Old 07-20-2021, 03:43 PM   #12
BlOody_BoOger
Aaaaaaand.
Still dead Probably just going to have it towed at this point. How’s that work if I can’t change the car into neutral and it’s at the top of a parking garage lol
There isn't a lil whole but the shift knob where you insert the physical key to allow you to go into neutral
Old 07-20-2021, 04:19 PM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Aaaaaaand.
Try disconnecting the negative terminal from the battery and leaving it off for at least 30 minutes to allow the static voltage to discharge from the car's electronics, then reconnect the battery negative terminal to the post. This will reset your ECU, possibly allowing you to start the car.
What gets me is that your radio does not come on. Sounds like you may have a couple of blown fuses.
You need to find out what the battery voltage is with nothing on inside the car, then while attempting to crank, before you go any farther.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 07-20-2021, 04:56 PM   #14
Cae2444
Drives: 2015 FR-s
Thanks! Was at least able to get it into neutral just now. Going to check fuses one by one and if I cant find a blown one, tow truck it is
Car won't start, not battery Gray Fox Issues | Warranty | Recalls / TSB 38 05-04-2021 03:19 PM
Won't start, new battery, no power sync32 Issues | Warranty | Recalls / TSB 5 02-07-2021 11:16 AM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
Car WON'T START dead battery? AnthonyArcaro Issues | Warranty | Recalls / TSB 17 01-19-2016 01:00 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
