Old 07-14-2021, 05:59 PM   #253
Chuckls
Moutain Runner
Originally Posted by czellers View Post
See the highlighted picture below. Are the louvers circled in this picture also a Verus product with a separate SKU product ID?
Hey boss, this is my car. I actually just moved to Raleigh. If you want to come out to Goodberrys tonight, I can answer any questions!
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
Lonewolf (07-15-2021)
Old 07-15-2021, 01:46 PM   #254
Grady
Grady's Avatar
The large vents will fit there.
https://www.verus-engineering.com/sh...32?category=41
Old 07-17-2021, 09:43 PM   #255
falcon_wizard
Drives: BRZ 2013
Use in winter with snow ?
Hey guys,
Anyone has had experience with the verus/velox hood vents in winters with snow ?
My car is a daily all year round, but goes to HPDEs a couple times in summer. I am thinking of adding those and install the water shields during winter time, or maybe keep them on and remove them when going to hpdes and put the wiskers instead, and then remove them and put the water plates back in when hpdes are done, assuming the operation is just a few bolts and won’t cause hood warping or loosing by have them added/removes a couple times a year.
Does this makes sense ?
falcon_wizard is offline   Reply With Quote
Old 07-20-2021, 12:52 PM   #256
Chuckls
Moutain Runner
I run my verus louvers open year round. Snow isn't an issue. It's just water. It'll evaporate when you warm the car up. The engine is mostly waterproof anyways.
Old 07-20-2021, 08:24 PM   #257
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Did you notch the lip around your oil filter? With my VIS AMS hood (with rain guards) it will still catch water and get a bit rusty. Not really an issue but, an annoyance.
Old 07-21-2021, 03:02 PM   #258
Chuckls
Moutain Runner
No I did not notch my lip at all. I probably should to allow water to drain, but it's already crusty.
Old 07-22-2021, 08:47 AM   #259
falcon_wizard
Drives: BRZ 2013
Thanks for the feedback. Noticing your location being from NC, I’ll « extrapolate » the feedback to Canada… It seems I get more snow in a week than NC gets in a year :-) and can get 5-7 ft of accumulated snow in winter :-)
Cheers
Old 07-22-2021, 10:07 PM   #260
Chuckls
Moutain Runner
Cheers
I was in indiana for two years with them. Received plenty of snow there.
Old 07-22-2021, 11:39 PM   #261
norcalpb
norcalpb's Avatar
For those that do those drive thru car washes…have y’all ever noticed oil temps drop like 20 degrees when water enters the hood? Does this call for concern?
Old 07-29-2021, 11:58 AM   #262
Chuckls
Moutain Runner
Can't say that I have since tS owners are suggested to not use drive thru washes per the owners manual.
Old 07-26-2022, 08:23 PM   #263
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just installed these. Looks way better in person than in photos.
NoHaveMSG (07-26-2022)
Old 07-27-2022, 06:45 PM   #264
YCK
Drives: Toyota 86 GTS 2019
DarkPira7e, the wickers seem to be mounted differently from the other photos of those vents, including Verus own website. Why did you put them on like that?
YCK is offline   Reply With Quote
Old 07-27-2022, 08:57 PM   #265
DarkPira7e
DarkPira7e's Avatar
I didn't read the instructions
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (07-27-2022), Ultramaroon (07-27-2022)
Old 07-27-2022, 10:15 PM   #266
lol should just leave it like that.
DarkPira7e (07-27-2022), NoHaveMSG (07-27-2022)
Verus Engineering Brake Cooling Kit VerusEric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 07-15-2023 11:18 PM
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 08:40 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 02:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
