#254 | |
https://www.verus-engineering.com/sh...32?category=41 |
#255 |
Drives: BRZ 2013
Use in winter with snow ?
Hey guys,
Anyone has had experience with the verus/velox hood vents in winters with snow ? My car is a daily all year round, but goes to HPDEs a couple times in summer. I am thinking of adding those and install the water shields during winter time, or maybe keep them on and remove them when going to hpdes and put the wiskers instead, and then remove them and put the water plates back in when hpdes are done, assuming the operation is just a few bolts and won’t cause hood warping or loosing by have them added/removes a couple times a year. Does this makes sense ? Last edited by falcon_wizard; 07-17-2021 at 08:57 PM. |
#256 |
Moutain Runner
I run my verus louvers open year round. Snow isn't an issue. It's just water. It'll evaporate when you warm the car up. The engine is mostly waterproof anyways.
#257 | |
Drives: RX-7 / BRZ
Did you notch the lip around your oil filter? With my VIS AMS hood (with rain guards) it will still catch water and get a bit rusty. Not really an issue but, an annoyance.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#258 |
Moutain Runner
No I did not notch my lip at all. I probably should to allow water to drain, but it's already crusty.
#259 | |
Drives: BRZ 2013
Cheers |
#260 | |
Moutain Runner
I was in indiana for two years with them. Received plenty of snow there. |
#261 |
For those that do those drive thru car washes…have y’all ever noticed oil temps drop like 20 degrees when water enters the hood? Does this call for concern?
#262 |
Moutain Runner
#263 |
Rust bucket enthusiast
Just installed these. Looks way better in person than in photos.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (07-26-2022) |
#264 |
Drives: Toyota 86 GTS 2019
#265 | |
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (07-27-2022), Ultramaroon (07-27-2022) |
#266 |
lol should just leave it like that.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | DarkPira7e (07-27-2022), NoHaveMSG (07-27-2022) |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 10:18 PM |
| Verus Engineering Air Oil Separator - Information and Release | VerusEric | Engine, Exhaust, Transmission | 127 | 07-08-2023 07:40 AM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
| Verus Engineering Carbon Thermoplastic Splitter Components | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 11-26-2017 05:23 AM |
