Old 07-09-2021, 09:54 AM   #1
curbybrz
OEM Rear Endlinks on SPC LCA's won't fit
Has anyone had this issue? I had to replace my sway bar endlinks and I can't get the endlink to fit in the LCA. Should I just hammer on it? Seems like that probably won't even work.
curbybrz is offline   Reply With Quote
Old 07-09-2021, 10:43 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Loosen the shock bolt, will allow stock LCA to spread open a smidge and endlink should fit in more easily. Just replaced my endlinks when I installed Eibach sways...
nathand (07-09-2021)
Old 07-09-2021, 11:28 AM   #3
curbybrz
That worked, thank you!!
Old 07-09-2021, 12:20 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Forgot to add, you should re-tighten the bolts with the suspension loaded up, i.e. wheels on the ground or supported on blocks or ramps. Basically you want the bushings in their "neutral" position with the car at static ride height.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Jdmjunkie (07-09-2021), nathand (07-09-2021), RToyo86 (07-09-2021)
SPL Rear Endlinks ottoyu34 Brakes, Suspension, Chassis 0 04-16-2021 05:27 PM
WTB: SPL Rear Endlinks EINSTEIN562 Want-To-Buy Requests 0 01-04-2021 09:31 PM
[OH] Mann rear swaybar, SPL rear endlinks, JDL UEL and HKS EL headers RRslip Brakes, Suspension, Chassis 3 12-12-2020 10:25 AM
[OH] JDL UEL and HKS EL headers, Mann rear swaybar, SPL rear endlinks RRslip Engine, Exhaust, Bolt-Ons 3 12-09-2020 01:27 AM
Wtb oem lca and rear endlinks bjun Want-To-Buy Requests 4 02-14-2017 02:11 AM
