Old 07-08-2021, 11:13 AM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
Question pipe between muffler and resonator looks strange
The pipe between my muffler and resonator seems rusted on my 2016 FRS, but neither the muffler or the resonator seems to be rusting. This is strange considering that all three are connected, and that somehow the pipe in between these two things became selectively rusted.
Is this normal or is this a cause for concern? And if it's an issue, what caused it and what could I do about this?
ghostzfh is offline   Reply With Quote
Old 07-08-2021, 12:16 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Likely different grade of stainless made from a different vender for Subie with possibly different post treatment process. Nothing to be concerned about, it will last another 20 years.
Old 07-08-2021, 12:31 PM   #3
fminicooper
Drives: FRS Hot Lava
Mine was all rusty as well.
Painted with black HT paint when I took apart for front pipe change.
fminicooper is offline   Reply With Quote
Old 07-08-2021, 12:46 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I just double checked, the stock rear muffler is aluminized mild steel. That is why the flange is so rusty at the joint. The mid pipe is going to pick up corrosion from heat cycling with debris stuck to it, and galvanic corrosion from being in contact with the muffler section.
Old 07-08-2021, 01:08 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
galvanic corrosion
*Something* always rusts
Old 07-08-2021, 01:17 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And stainless will corrode sooner if it is in contact with a ferrous metal(galvanic corrosion).
Old 07-08-2021, 01:39 PM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
Megan Racing has a replacement or you can get the remark one.
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 07-08-2021, 02:31 PM   #8
Yoshoobaroo
TRACKBREAD
Oooor you can wait until there’s a hole in it.
Old 07-08-2021, 04:03 PM   #9
galvanize this
Old 07-08-2021, 06:02 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
galvanize this
Just don't attach yourself to any dissimilar materials and you will be fine.
Old 07-08-2021, 06:10 PM   #11
lol...
you totally win
Old 07-08-2021, 06:21 PM   #12
Yoshoobaroo
TRACKBREAD
Old 07-08-2021, 06:35 PM   #13
10/10 many layers
Old 07-08-2021, 09:50 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
i think you need to spend more time driving your car and less time laying underneath it!
exhaust, rust
Using a muffler as a helmholtz resonator Ashikabi Engine, Exhaust, Transmission 10 07-16-2020 02:24 PM
Resonator or muffler delete? Gatoortiz86 Engine, Exhaust, Transmission 10 01-02-2019 03:55 AM
Berk Muffler Delete with Resonator BigTuna Engine, Exhaust, Bolt-Ons 9 12-05-2017 03:19 PM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 06:42 PM
