#253 | |
Drives: 2017 BRZ series.yellow
On the last part, I'm selfish and I don't want the second gen in STX because it will be the same thing as the ND1/ND2 probably from a few years ago. I was hoping they were finally going to turbo it so it would be guaranteed to not be in STX, lol. |
#254 |
Regarding the ND Miata in STR, let's not forget that the Miata is the most raced car in the world, the SCCA has a couple road racing classes just for Miatas, and Mazda sponsors a driver's dinner at Solo Nats. They had the car out there the year prior for demo times and clearly worked with the club to get the classing. Finally, a whole bunch of top drivers jumped into the Miata to pick up contingency money (let's not forget the money).
I'd say it's a bit of a special case. Now maybe that scenario does in fact play out with the second gen BRZ/86, but it could also be that using the ND Miata as the model for what the SCCA will do and how it will turn out is not a valid assumption. Me, I'm going to Richmond on Saturday for the VMSC practice event, get me some seat time
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
#255 |
Drives: 2016 HyperBlue
#256 |
At the track
Drives: '14 FRS - Former e92 M3
More battery questions lol
Is the MeLe really the best hold down option for the antigravity RS30? Seems to be popular in here. Price seems really high but the part looks quality... Trying to find an alternative option. Antigravity sells a tray for but it doesn't look great for the money either. Any other alternatives? |
#257 |
I've only run the car in one event and it's the only one I've tried so I don't have much opinion other than it's a nice quality piece. Right now it's set to full soft, that seemed like a good starting point as full soft is around twice as stiff as the stock bar.
| The Following User Says Thank You to Autoxer62 For This Useful Post: | nathand (07-03-2021) |
#258 | |
Drives: 2016 Scion FRS
Antigravity: A friend of mine killed a Restart 20 in his BSP car at Bristol this week. Started getting some weird dash lights, then the car wouldn't start and the battery had bulged. Granted, the battery location is in a better spot for mitigating heat in a twin versus an ND, but Kyle ran into issues as he got more into tracking his former STX car. So now I'm in a spot where I paid top dollar for the best and I feel like I need to carry around a backup battery and mounting options. MeLe: I don't know if I ordered the wrong box or they sent me the wrong box or something changed in how the battery mounts from 2013 to 2016, but the orientation to the mounting plate wouldn't work for my car. Fortunately, I was able to use washers in the slots to mount the tray, then spin a nut on upside down bolts to mount the box to the tray. It looks nice in the car and the battery isn't going anywhere, but for the money, it is pretty unacceptable to have to rig up a mounting solution. |
#259 | |
At the track
As far as the battery goes the 20 seemed a little small so I'm trying the 30. I talked with their sales rep Bart last week and went over all their options with him so fingers crossed it works well (I plan to leave it on a trickle). I liked the one I had in my BMW but it was much larger. |
#260 | |
#261 | |
Drives: 4 wheels
| The Following User Says Thank You to justint5387 For This Useful Post: | e1_griego (07-07-2021) |
#262 |
Notes from Richmond on RT660 tire pressures:
I went to the practice event at RIR, the lot is kinda crumbly asphalt, ended up getting 15 runs in three heats, weather was 80 and mostly sunny. I started off at 32 psi and checked temps after a couple runs and eyeballed how far the tire rolled, and dropped the pressure to 31 then 30 in the second heat. I re-checked the temps (infrared, not probe) and they were decent across the tread and the car felt pretty good. Some caveats - I have a very basic setup with only 2.5 deg front/2 deg rear camber. I'm also rather out of practice, so I'm slow (2 seconds off the good STX guys there). I'll post an update when I have a better setup/driver/data, but if one is running these tires and wants a starting point I wouldn't go higher than 32.
#263 | |
Drives: 2013 Subaru BRZ
#264 | |
Custom User Title
It's a simple calculus: Do you want the car or don't you? If you want the car then buy it, drive it in local events, and write in to request classing. If you don't want the car and would only begrudgingly buy it to drive it in STX if/when it's ever classed that way then don't buy it and let it get classed or forgotten about. I think all these comparisons to the ND1/ND2 in STR are Apples to Oranges. We're talking 8 model years of the FT86 vs. just barely over 2 model years of the ND1.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#265 | |
#266 |
Custom User Title
I imagine you won't be the only one with that sentiment. I don't feel any particular attachment to my FT so I'll buy a GR and futz around in it for a few years. If it doesn't get classed competitively eventually that's fine I can move on.
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 03:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 02:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
