Old 07-06-2021, 09:40 PM   #15
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by churchx View Post
But they won't suffer from eg. excessive cooling off driving through puddles? Or compound of these tires doesn't need to be brought upto temps?
Both the RE71R's and the A052's work well at fairly low temperatures. x2 Both RE71R's and AO52's are excellent in the wet. Now tires like the RS4 on the other hand are terrible in the wet because exactly the opposite.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
ZDan (07-07-2021)
Old 07-06-2021, 10:10 PM   #16
jflogerzi
jflogerzi's Avatar
Tire rack has 235/45/17s on close out for 125$ a tire. Gonna give these a shot. First real 200TW tire. Looking forward to doing some laps in the fall with these and Sonoma in August. RE-71s
2013 Series 10 FRS #553
Old 07-06-2021, 11:22 PM   #17
Goingnowherefast
Spoiler alert: You'll literally never go back
Old 07-06-2021, 11:30 PM   #18
jflogerzi
jflogerzi's Avatar
But my wallet can't afford that. Hence have SX2's for general track days and throw these on for a session or 2. But I am excited to try these. The grip difference is gonna be
Old 07-07-2021, 07:57 AM   #19
steverife
Drives: 2016 Scion FRS
The A052's are king in autocross (if you have camber) and it isn't even close.
steverife is offline   Reply With Quote
Old 07-07-2021, 08:26 AM   #20
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I would believe that. Haven't gotten much track time in this car but with my E46 (~3300 lbs) I had RE-71's and later RS4's. The RE-71's would overheat after about a lap and a half in time attack (felt greasy and soft). The RS4's would just about last a 15 minute session.
I don't have actual wet track experience though.
CrowsFeast is offline   Reply With Quote
Old 07-07-2021, 09:42 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
RE71R and A052 are very good even cool. The A052 in particular will fall off after a couple/few laps due to heat. These tires are kind of optimized for autoX and time trials more so than long stints on track, they have plenty of compound grip in cool/wet conditions.
Old 07-07-2021, 11:22 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hard to beat the SX2's for the price but I think next time I am going to go 615K or RS4 for a "beater" tire. I can't get over how bad the SX2's are under braking. It is disproportionally bad to the amount of lateral grip they have.
Old 07-07-2021, 12:53 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Good info from Grassroots Motorsports
https://grassrootsmotorsports.com/ar...Ui_BtNtQH2xbrg
The Following 13 Users Say Thank You to ZDan For This Useful Post:
bhmax (07-07-2021), Bonburner (07-20-2021), churchx (07-07-2021), DarkSunrise (07-07-2021), Dzmitry (07-08-2021), glhs386 (07-16-2021), jflogerzi (07-09-2021), nathand (07-07-2021), NaturallyAspirated (07-11-2021), NoHaveMSG (07-07-2021), Ohio Enthusiast (07-07-2021), SCFD (07-07-2021), yberther (07-30-2021)
Old 07-14-2021, 06:08 PM   #24
jflogerzi
jflogerzi's Avatar
based on this chart the 660's look to be best all-around 200TW tire that can kinda do it all. Solid crossed the board but nothing outstanding.
Old 07-19-2021, 02:09 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I finally have a significant amount of time on the RT660's. I would say they feel similar to the Dunlop Z3. A little less feel, a little more grip. Communication is decent, audibly and through feel. Wear is okay, mine have about 6 20 minute sessions on them and they are looking ok. I expect about 5-6 track days. Heat tolerance is okay, after a couple push laps you can tell they are starting to fall off, still reasonably quick but not quite there. After 4-5 hard laps they can use one slightly backed down, but still won't be quite as quick as the initial couple. They seem to like about 37psi hot. Any lower and they where starting to roll over on me. I initially ran them for 2 session about 3 weeks ago. Before this last track day I checked them with a cheap durometer gauge and they where clocking in around 68-70 shore A all the way across. After 4 sessions Saturday I checked them this morning, they are still reading about the same.
jflogerzi (07-19-2021)
Old 07-19-2021, 02:27 PM   #26
jflogerzi
jflogerzi's Avatar
How would you compare these to Yoko and RE71s
Old 07-19-2021, 02:38 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I haven't run either of those. Just the Dunlops, and the Hankooks as far as 200TW tires.
Old 07-20-2021, 12:25 AM   #28
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Going by this chart alone the Kumho, BFGoodrich, Michelin, and Goodyear are better with no tradeoffs within that super 200 category.
New 200tw tire from Continental RayRay88 Tracking / Autocross / HPDE / Drifting 24 08-23-2021 12:23 PM
Maxxis VR-1 (New 200TW tire) CSG Mike Tracking / Autocross / HPDE / Drifting 64 03-31-2021 04:10 PM
Unusual Tire Wear - Test xdavidx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 10-10-2019 07:49 PM
Maxxis VR-1, New 200TW "Extreme summer performance" tire CSG Mike Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 06-01-2016 05:04 PM
