Old 11-05-2020, 10:44 AM   #15
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Hudzoyne View Post
Dont forget the one on the right hand side head at the front under the injector cover, usually used to feed the vacuum pump on auto cars. But if you have a manual you have a good oil feed location there. M12x1.5 IIRC
Are you referencing the cam cover on the BACK of the engine? The location you're referencing (right side, front, on the head) doesn't have a plug that I'm aware of
Old 11-05-2020, 11:33 AM   #16
Hudzoyne
Drives: Turbo GT86 - Fensport Performance
Right here, we use this as the turbo oil feed on avo turbo kits. Its also fantastic because it is the very last thing that is fed with oil in the whole circuit so doesn't take any oil flow away from anything
Hudzoyne is offline   Reply With Quote
The Following 4 Users Say Thank You to Hudzoyne For This Useful Post:
Bonburner (11-06-2020), DarkPira7e (11-05-2020), jrhudson (07-03-2021), Ultramaroon (11-05-2020)
Old 11-05-2020, 11:51 AM   #17
Originally Posted by chipmunk View Post
What's the thread size on the OEM pressure sensor?
It's a 1/8" BSPT (not NPT!)
chipmunk (11-05-2020)
Old 11-05-2020, 01:16 PM   #18
DarkPira7e
DarkPira7e's Avatar
That's awesome. Thank you!
Old 11-06-2020, 08:00 AM   #19
chipmunk
Drives: _
Interesting! I guess we do learn something new everyday!
Have you happened to measure the pressure difference between the OEM sensor location and this right head port?
chipmunk is offline   Reply With Quote
The Following User Says Thank You to chipmunk For This Useful Post:
DarkPira7e (11-06-2020)
Old 07-03-2021, 06:43 PM   #20
jrhudson
Drives: 2016 scion frs
do you know what the thread type on this one? 1/8 bspt? 1/8 pt?
jrhudson is offline   Reply With Quote
Old 07-03-2021, 11:31 PM   #21
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It is PT, which is interchangeable with BSPT, and neither is compatible with the tapered NPT.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
jrhudson (07-04-2021)
E85 locations cuddefred AUSTRALIA 7 10-28-2017 06:13 AM
Oil galley temp reading low Tomita San Engine, Exhaust, Transmission 19 03-14-2017 05:22 PM
Oil Galley Plug Adapter Wyattkb Engine, Exhaust, Transmission 3 12-21-2015 01:10 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
