Old 06-29-2021, 05:26 AM   #1
Sean 86
Sean 86
Drives: 2019 Toyota 86 TRD SE
CV Axle Failure after 8.6K Miles?
I drive a 2019 Toyota 86 TRD SE. I haven't even hit 10k miles but I am already hearing a clunking noise from the back which I assume is the CV joint from the axle because it follows the rhythm of the car speeding up. I do track it at the Nürburgring and have done 6 laps of the north loop and 1 session at the GP track. Is that enough for the axle to break at less thank 9K miles? I'm going to try to have it replaced under warranty but I know that's no guarantee, but maybe German dealerships are different. Anyone else have problems with the axle breaking that early?
Sean 86 is offline   Reply With Quote
Old 06-29-2021, 09:10 AM   #2
Mods to suspension?
Old 06-29-2021, 11:56 AM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
I would talk to the guys at Apex as they have a lot of experience with this platform on the ring.
Also which side of the car did the axle fail on? I believe it is the left side where the exhaust comes quite close to the cv boot and has been a known failure point.
Jdmjunkie is offline   Reply With Quote
Old 06-29-2021, 03:35 PM   #4
Sean 86
Sean 86
Mods to suspension?
No suspension mods, only enkei wheels in the OEM size
The Following User Says Thank You to Sean 86 For This Useful Post:
Tcoat (06-29-2021)
Old 06-29-2021, 03:37 PM   #5
Sean 86
Sean 86
I was going to hit them up and talk to them about their 86. I have lots of questions, especially since they don't run an oil cooler. And I believe right side. I haven't had a chance to get it on a lift yet but the sound appears to be right side but mine is a dual exhaust
Old 06-29-2021, 07:37 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It follows the rhythm of the car speeding up but does it vary with load? CV axles typically won't behave badly when they aren't loaded.
Old 06-30-2021, 07:45 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hit any curbs at the track particualry hard?
Any off track excusions?
Old 06-30-2021, 09:02 AM   #8
Sean 86
Sean 86
It's quite noticeable when braking
Old 06-30-2021, 09:04 AM   #9
Sean 86
Sean 86
Nothing that would make me cringe. I've been on a lot of the apexs and some curbs but nothing that you're not supposed to be on
x808drifter (06-30-2021)
Old 06-30-2021, 11:08 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pretty strange to loose a CV that quickly. I have over 90K miles on my car, tons of track days, very low on coilovers. I just replaced my original CV's, but they didn't need swapped.
Old 06-30-2021, 12:51 PM   #11
RZNT4R
Then I'd pay attention to the brakes first, braking doesn't load the axles.
axle, cv joint, track, warranty
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
Headlight Failure FRSNewb Issues | Warranty | Recalls / TSB 9 06-04-2015 09:39 PM
Engine failure - 38,000 miles Mr 286 Issues | Warranty | Recalls / TSB 217 10-05-2014 09:52 PM
DI Failure Issue Taber Issues | Warranty | Recalls / TSB 123 07-19-2013 05:20 PM
