Old 03-20-2021, 06:26 PM   #113
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Compelica View Post
You can thru the extended OBD2 PIDs, but they are nowhere as fast or instant as reading from CAN.
As long as the sensitivity of the signal is constant, as we only want to know what the difference in how intrusive the VSC is between the 2 different modules.
PIDs or direct from CAN, either way, how do we log it simultaneously with the other pertinent parameters? Torque app can do this? What do you need?
Edit: Better yet somebody define the traction control maps and we can just alter the maps, if that's possible. "reflash" the VSC module lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Jdmjunkie (03-20-2021)
Old 03-20-2021, 11:12 PM   #114
Compelica
Compelica's Avatar
Drives: 86 GT
It's in an app called OBD Fusion - however it's a paid addon, and the downside is that the PID formula isn't shown (you can only access the values) so along with individual wheel speeds you can monitor these VSC parameters below.
Compelica is online now   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
solidONE (03-21-2021)
Old 04-28-2021, 11:00 AM   #115
MR2Dave
Poop train conductor
Drives: 2015 BRZ Ice Silver Metallic
Thanks so much for the guide.
I swapped a 2019 ABS module into my 2015 and it just works, didn't even get an ABS light after.
The only thing I'd add is that, when disconnecting the module, push the lever all the way up until it clicks to release it. It took me longer than it should have to figure out why it wouldn't let go of the connector. =)
MR2Dave is offline   Reply With Quote
The Following User Says Thank You to MR2Dave For This Useful Post:
Yoshoobaroo (05-04-2021)
Old 05-04-2021, 02:32 PM   #116
blatantanomaly
Drives: 2016 BRZ Limited
I put a 2018 VSC module in my 2016 BRZ and now my radio is messed up?? It won't let me play anything but this song
Edit: Seriously though, I bought a module from Mike_ZN6 on here, installed it in less than 10 minutes since I didn't have to re-pin anything and a regular 4 mm socket works on the 4 mm e-torx (thanks for that tip!). I didn't disconnect the battery during installation, but my key fob wasn't anywhere near the car. Slapped it on and fired it up; saw no warning lights whatsoever. The VSC Sport button required a 1-second press instead of being instant-on as described. Later that evening I took a U-turn like a complete asshole and only when I got close to one full turn of counter-steering did VSC kick in like "Easy there, Keiichi" and just nudged the rear end back into line instead of shutting down the whole party like Sport Mode used to. Definitely a worthwhile mod. It'll be nice having a safety net instead of having to choose between training wheels or nothing at all on track days.
blatantanomaly is offline   Reply With Quote
The Following 3 Users Say Thank You to blatantanomaly For This Useful Post:
jflogerzi (06-29-2021), norcalpb (06-02-2021), Yoshoobaroo (05-04-2021)
Old 06-02-2021, 04:33 AM   #117
AleksShamles
AleksShamles's Avatar
Drives: Just a student
Good
AleksShamles is offline   Reply With Quote
Old 06-10-2021, 05:38 PM   #118
killy
Drives: BRZ Limited
Hi, just a question, I too noticed that the VCS sport now requires a longer press to activate.
Does your TRC button works the same as before the swap?
mine does not. If I hold it for 3+ seconds it lights up the TRC off and the ESP icon as before, but when i press it and immediately let go, on the old module it would light up only the TRC off light (and if i went 40+ it would engage again the TRC and the light would go off). Now if i press the trc button and let go no lights turn on....
it is strange. did I lose the feature?
not that i ever used it, just to know....
killy is offline   Reply With Quote
Old 06-19-2021, 12:28 AM   #119
norcalpb
norcalpb's Avatar
I have a 2013 with this mod and I have retained the “bad road mode” which is the immediate press of the TRC button. What year is your car?
Old 06-23-2021, 12:24 PM   #120
XCRACER
Drives: Future FT86
Thank you for the fantastic thread and information. Picked up 2017 VSC module for my 2015 FRS MT and plug and play just as described. Can't wait to get it on the track at Mid-Ohio in a couple of weeks!
XCRACER is offline   Reply With Quote
The Following 2 Users Say Thank You to XCRACER For This Useful Post:
bhmax (06-29-2021), Yoshoobaroo (06-23-2021)
Old 06-28-2021, 11:11 AM   #121
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Anyone running this mod on a daily driver? I have a 2013 and this looks VERY tempting...
Any undesirable side effects?
Thanks!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 06-28-2021, 01:03 PM   #122
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Thanks!
I daily my car with this mod. No side effects.
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
nextcar (06-28-2021)
Old 06-28-2021, 02:29 PM   #123
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Thanks!
I daily mine, no side effects. I haven't activated the hill climb assist but many people say it's more annoying than helpful.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
Old 06-29-2021, 05:24 PM   #124
nextcar
Wish me luck...
Found a 2017 MT, non PP unit for $99... but the recommended LeeC/417 sellers on ebay now want $300-$350 for these, so shop around. It is probably a little early for me to say I got a deal; I am still a bit nervous until I can inspect the date codes and part numbers to see if it really is the unit I need. Oh well, looking forward to this!!!
Pull out
The Following User Says Thank You to nextcar For This Useful Post:
Yoshoobaroo (06-29-2021)
Old 06-29-2021, 11:44 PM   #125
jflogerzi
jflogerzi's Avatar
Wish me luck...
Found a 2017 MT, non PP unit for $99... but the recommended LeeC seller on ebay now wants $300-$350 for these, so buyer beware. It is probably a little early for me to say I got a deal; I am still a bit nervous until I can inspect the date codes and part numbers to see if it really is the unit I need. Oh well, looking forward to this!!!
Thats a steal! I was going to do this but now I will just roll with the pedal dance
2013 Series 10 FRS #553
Old 06-30-2021, 07:19 PM   #126
nextcar
Other than going out and trying to slide... is there a quick way to verify the new functionality is operating correctly? I may get a chance to do the swap this weekend - would be nice to know it is all working correctly after I am done but before I really need it!
Pull out
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
