Old 06-09-2021, 04:16 AM   #127
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Originally Posted by gpvecchi View Post
Some times ago I fitted the STi JDM axleback, instructions said to replace nuts, gasket, and hangers, but I didn't do it as my car was new.
I was happy with the sound, except an annoying resonance at 3000 rpm.
I asked here, and I was said it was drone, nothing to do, characteristic of the exhaust; it was not drone to me, but a resonance inside the cabin.
Recently I discovered a japanese article: I was right, and I made a great mistake.
I didn't check the part numbers of the additional parts, as I took for granted that they were the stock ones; but the hangers weren't, they were a different part number!
The article said that the cabin resonance frequency of the 86/BRZ is 125 Hz, and the STi steel exhaust (the titanium one don't) needs that specific hangers to avoid the noise. AND THIS WORKS!
If you have resonance, and you want to try risking just few bucks, you have to replace just the 2 rear hangers (the ones toward rear bumper) with 44066AJ010 part number. The front ones has to remain stock.
Were you able to check the weight of the muffler vs stock? How's the sound from the inside the cabin & outside? Was it worth it to spend about 2k on the STI than the others that are about 50% cheaper (if you factor in import taxes & shipping)? Is the midpipe included too?
I used to have the TRD Exhaust on my FRS & it was a bit loud to my liking & droney too.
TIA
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 06-09-2021, 04:56 PM   #128
gpvecchi
gpvecchi's Avatar
Sorry, I can't check the weight as it's fitted. STi exhaust is an axleback. The outside sound is perfect, beefy, not too silent and not too noisy.
The inside sound is meh, at lower revs it's a little strong, in particular around 3000 rpm (but I think every exhaust will be noticeable at that rpm), quite silent at higher revs.
It worth the price if you care of the brand STi, it's particular construction and its wonderful exit pipes. Plus, this exhaust has a quiet and wonderful noise when catless...
Old 06-09-2021, 07:41 PM   #129
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
My understanding (happy to be corrected) is that the Fujitsubo Authorize S is a nearly identical axle-back to the STi. I haven't seen the two side by side, but the photos of each make it seem true.
Cephas is offline   Reply With Quote
Old 06-09-2021, 08:11 PM   #130
N_Raged
Drives: 2019 BRZ Sport-Tech RS
They're quite different IMO. The STi is a flow-through resonator that goes into into a small chambered silencer - all packaged neatly into the dimensions of the stock muffler. While the Authorise S is just a big chambered silencer.
From the various sound clips I've seen. The STi has more bass and growl, while the Authorise S is more plain in its tone.
N_Raged is offline   Reply With Quote
The Following 2 Users Say Thank You to N_Raged For This Useful Post:
Cephas (06-09-2021), jflogerzi (06-09-2021)
Old 06-10-2021, 02:21 PM   #131
N_Raged
Some more thoughts on how those two compare.
The Authorize S sounds like the stock muffler uncorked - a little bit louder and clearer tone but still very much the same plain character of the stock exhaust.
The STi muffler has a more distinct character to it. More refined, very deep tone, not raspy or tinny.
Old 06-11-2021, 06:55 AM   #132
Cephas
Cephas's Avatar
That's good info. Have you been able to find sound clips online to compare? Bonus points for catless UELs...
Old 06-11-2021, 08:47 AM   #133
N_Raged
This playlist I put together:
https://youtube.com/playlist?list=PL...8kCS1eQkBLXS5J
The Following User Says Thank You to N_Raged For This Useful Post:
Cephas (06-12-2021)
Old 06-14-2021, 04:35 AM   #134
Compelica
Compelica's Avatar
Drives: 86 GT
Received my hangers a few days back, will report once I get the chance to install them.
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
spcmafia (06-14-2021)
Old 06-14-2021, 09:21 AM   #135
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Discovery on STi JDM axleback and perhaps others
Finally able to report back in brief, as I installed all 5 on my car a few days back while pulling it out of winter storage (a little late, I know). Took 10 minutes with a can of WD40 to help wrestle the stock hangers off.
For reference, my exhaust setup:
- JDL 4-2-1 EL Header
- Stock OP/FP
- Invidia R400 cat-back
This setup is far from the loudest but it is not quiet when you are on throttle. Under low load it remains basically as quiet as stock in the city, but on the highway especially going up hills (where mild load is introduced) I was getting drone right in my cruising speed of 120-130kph (3400-3600rpms-ish).
I’m actually alarmed at how much of a difference these hangers make. The volume of your exhaust is still there (obviously), but with literally none (!) of the cabin resonance and drone, which makes it so much more livable, especially on the highway.
I was going to add an additional resonator to my setup or swap my catback to quell my drone issues on the highway, but with this quick fix, I don’t have to anymore.
Thanks to @gpvecchi for sharing this with the community!
PS: To any one concerned about exhaust movement with these hangers, I actually had some midpipe movement with my stock hangers that I could hear when entering driveways (midpipe touching the tunnel). With these new hangers installed, that movement is gone.
JBezugs is offline   Reply With Quote
The Following 9 Users Say Thank You to JBezugs For This Useful Post:
Cephas (06-14-2021), DarkSunrise (06-14-2021), gpvecchi (06-14-2021), jflogerzi (06-14-2021), NLSP (06-16-2021), norcalpb (06-14-2021), Overdrive (06-14-2021), saltywetman (06-20-2021), Thefalls (06-14-2021)
Old 06-16-2021, 12:23 PM   #136
femaledog
Drives: 2017 BRZ Perf. Pkg.
Based on the posts in the thread, I ordered a set. I've got some annoying resonance with the Legsport "Race" exhaust and if it helps get rid of that its worth a shot. I'll post an update with my opinion once I have the parts installed.
femaledog is offline   Reply With Quote
Old 06-18-2021, 12:18 AM   #137
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Decided to be proactive and order a set of these for when the exhaust mod happens. It's too inexpensive a thing to not try. Took a little over 2 weeks from ordering for them to ship, not too bad at all.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 06-19-2021, 03:55 PM   #138
SumDizzy
Drives: Silver 2018 Toyota 86 GT
Really glad I stumbled on this thread. Just installed the 3" Perrin Resonated catback this weekend and noticed quite a jump in cabin vibration. Chalked it up to the blown cat in my OEM front pipe (unfortunate discovery when taking off the stock muffler and still need to address). Really confident this will help, but probably won't see it for at least a month.
SumDizzy is offline   Reply With Quote
Old 06-22-2021, 12:31 PM   #139
rixter145
Sleep Chomper
rixter145's Avatar
My exhaust recording on outside..
Interior wise, it tuned out a lot of the unwanted frequency, resulting in a better cabin cruise... from time stamp 2:50 onwards, noise interior wise was the quietest at 3.5k rpm as it had the best cancellation
ymmv though as mine is a full titanium catback
Sent from my XQ-AS62 using Tapatalk
rixter145 is offline   Reply With Quote
Old 06-22-2021, 10:14 PM   #140
Compelica
Compelica's Avatar
Drives: 86 GT
@gpvecchi do you still have that article you were referring to? Would like to do a read if you still have it.
Ecutek discovery solidsnake11 Software Tuning 7 08-25-2020 07:38 AM
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 10:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
