#225 | |
At the track
Drives: '14 FRS - Former e92 M3
Where is your understeer? Mid corner? Corner entry? Exit? This is a good simple guide on things to adjust with setup depending on how your car is behaving. https://drivingfast.net/understeer/ |
#226 |
Drives: 2016 Scion FRS
One thing to keep in mind is that 28 psi on my gauge might be 26 psi or 30 psi on someone else's gauge. So don't marry a number you got from someone else.
With that said, 35 does seem high. |
#227 | |
Drives: 2013 BRZ Limited - stock
I appreciate everyone’s input. I will read the link after dinner. |
#228 | |
Drives: Some kind of Subaru
#229 | |
I think the toe in is a big deal. I've ran pressures around 32 or so and thought the car was fine. The 400 lb front setup isn't inherently pushy and neither is running a 22mm bar on soft. Same for -3.5 degrees camber. We haven't really spoken of coilover adjustments or rear bar. |
#230 | |
Drives: Miata
When will the GR86 be available? Will it make it to STX?
#231 | |
The Stig's German cousin
My money is on yes for STX. My money is also on a 4.3 rear end. I won't put money on it, but I think it'll be faster assuming you can get the third gear stuff right. That's really not enjoyable at an autocross though (it's additional opportunities for strategy or execution mistakes), so I'm loathe to try. |
#232 |
Drives: '13 FRS - STX
Brand new cars don't typically go into ST their first year, I think the old chassis (and RX8) is safe for '22 but the new chassis may go in for '23 or '24. STX participation is still solid so I don't think there will be a rush to throw an 'overdog' into the mix that's still under bumper-to-bumper warranty.
With the added speed it might open up the opportunity to pick up some STR/STU backmarkers as well, E36 M3 and S2000 come to mind as good cars that are affordable and not really competitively classed currently. Maybe the NC Miata too. Agreed the 2.4L torque will help the car a ton, some good drivers will be able to do the 2-3-2 shift seamlessly and we already know if Subaru is on their game the valvetrain can handle 8k rpm to mitigate the stunted gearing. |
#233 |
Between COVID last year and not being able to get tires this year, the 2.4 car going to STX next year would be a real cherry on top of my STX build failure sundae.
#234 |
At the track
I think we'll get another year or two of current car STX. By then my car will either be a full-blown crazy TT car with a motor swap or I'll be buying the new car and figuring out how many of my current parts I can maximize swapping over. Either way, I agree '23-24 at the earliest.
#235 |
Drives: Many
The conversation I've heard is STR the first year so they don't upset the STX applecart, which makes sense. If it does got to STX I'll (reluctantly) buy one since I suspect all the fun (read:expensive) parts swap over.
#236 | ||
Drives: Miata
![]() Any chance for different gearing between the BRZ and 86? Quote:
#237 | |
Edit: above looks like clickbait with zero substance. More likely they were later to finalize the bumper covers or have tweaked springs and dampers again like the first two years. Every delta between the two costs hundreds of thousands of dollars, doubt they'd waste that on a one off transmission that nobody will notice. Last edited by strat61caster; 06-22-2021 at 03:28 PM. |
#238 | |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 11:27 AM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
