Old 06-22-2021, 12:21 PM   #71
Originally Posted by Yoshoobaroo View Post
But the convertible had sliding rear side windows. The pop out ones were probably just used because they’re cheaper. No regulator, and the pop out mechanism was used in a bunch of 90s coupes and hatches, probably because A/C wasn’t standard on most cars. The next 3 series coupe they just made the rear side windows fixed.
The convertible has a taller but narrower window that will fit down between the door frame and the rear wheel well. The wider window of the coupe would just not have space to go down into. Sure they could have made the window narrower but that would spoil the roof line.
Yoshoobaroo (06-22-2021)
Old 06-22-2021, 12:25 PM   #72
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Good point, I never realized how much smaller they were.
Old 06-22-2021, 12:30 PM   #73
The only other way to deal with the space issues are those bloody stupid only go half way down rear windows some makes use. Why bother when it will only open 3 inches?
Dadhawk (06-22-2021), Yoshoobaroo (06-22-2021)
Old 06-22-2021, 12:43 PM   #74
pzerok
Drives: GR86
The car was never designed for FI from the start and heat is certainly a factor. They always have said they will never go turbo. Not sure how it is a surprise to anybody that it is not set up for nor "easy" for them to do it and meet the demands they need to meet.
Sure you can slap one into it but that does not mean they can.
As I have said 1,000 times there will never be a factory turbo Twin no matter what the internet armchair experts may think.
They've always maintained they won't Turbo the twins but people keep "hoping". This is just like how everyone keeps "hoping" there will be a manual Supra. Is it a non-zero chance? Maybe. Is it likely though? Probably not.
There's already quite a small gap between the new model's ~220hp and the 2.0L Supra's ~250hp. They may want to keep the gap clear.
pzerok is offline   Reply With Quote
The Following User Says Thank You to pzerok For This Useful Post:
Tcoat (06-22-2021)
Old 06-22-2021, 12:52 PM   #75
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I have this terrible 1st year FRS issue called power oversteer on command with only 200HP. I'll never buy a 1st year car again.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
kaputt (07-25-2021), Tcoat (06-22-2021), Yoshoobaroo (06-22-2021)
Old 06-22-2021, 12:52 PM   #76
EAGLE5
Dismember
EAGLE5's Avatar
There are a ton of turbo and supercharged twins. Anybody waiting for Toyota and Subaru to do the job for them are nincompoops. Do it yourself.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Tcoat (06-22-2021)
Old 06-22-2021, 01:09 PM   #77
Yoshoobaroo
TRACKBREAD
Is there a turbo kit that is close to OEM quality though? The Works kit is the only one that comes to mind, but IIRC the power bump isn’t much. As far as superchargers only the Harrop kit really works well. Any Rotrex unit needs stupid friction fluid and the Edelbrock unit has MAF reading issues.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
vintagemxer (06-22-2021)
Old 06-22-2021, 01:13 PM   #78
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
The power bump for Works turbo kit is right near 100HP, which in terms of OEM style, sounds like way plenty for this car. I wouldn't expect any more, as reliability issues will start to creep up.
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
vintagemxer (06-22-2021), Yoshoobaroo (06-22-2021)
Old 06-22-2021, 01:16 PM   #79
The power bump from a stock one wouldn't be much either. And the OEM "quality" could be hit and miss as well really. Besides a Supra priced Twin would probably kill it not sell more.
Old 06-22-2021, 03:30 PM   #80
EAGLE5
Dismember
EAGLE5's Avatar
Not many complaints about SBD, and they're cheap. Get one and a conservative custom tune and you'll be golden.
Old 06-22-2021, 03:43 PM   #81
Yoshoobaroo
TRACKBREAD
Anyone not buying to avoid early issues like 1st gen FRS?
Sorry, but a Greddy knockoff isn’t even close to what I’d call OEM-like. The exhaust manifold design alone turns me off, a rigid manifold cantilevered out in front, it’s like asking for it to crack. The bumper beam modification is a hard no for me too, Crash structure is extremely sensitive to changes which will affect how it crumples. I want it to crumple exactly as Subaru designed it to, no more, no less, and the same shape. Personally I want to keep the primary cat as a minimum as well.
The only 2 FI kits that satisfy me from a design aspect are Harrop and Works. Every other kit has too many compromises or weird workarounds like a custom front sway bar, cut crash structure or 2 miles of cold piping.The works kit loses the OEM strut tower braces which I don’t like at all but at least you can fit a tower-to-tower bar. The Coyoda turbo kit designed by Turboyoda looked good too but I don’t think they ever got it in production.
Dzmitry (06-22-2021)
Old 06-22-2021, 04:38 PM   #82
EAGLE5
Dismember
EAGLE5's Avatar
Sounds like you have two options you're happy with, then. What's to be unhappy about? Why wait? Go for it.
Old 06-22-2021, 06:59 PM   #83
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Buy early. Wreck early.
That way I can buy early too!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 4 Users Say Thank You to Dave-ROR For This Useful Post:
Dzmitry (06-22-2021), nextcar (06-27-2021), Tcoat (06-23-2021), timurrrr (06-26-2021)
Old 06-22-2021, 07:12 PM   #84
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
My 2000 Dodge Ram has pop out back windows, and I love them
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
What issues should i look for why buying a used FR-S? Jaredtri589 Issues | Warranty | Recalls / TSB 27 05-29-2019 02:27 AM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 08:56 PM
Main issues to look for when buying? PSim Issues | Warranty | Recalls / TSB 14 02-12-2018 11:12 PM
Is there any issues with buying a used OFT? wise345 Software Tuning 17 01-24-2016 01:36 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 04:42 AM
