Old 06-11-2021, 11:38 AM   #1
dencepro
Shocks Upgrade
It's been a while since I have started thinking of upgrading the shock absorbers on my 2013 Subaru BRZ Limited. Thinking of checking out Bilstein Shocks. Has anyone tried their B6 Series Shock absorbers?
dencepro is offline   Reply With Quote
Old 06-11-2021, 11:48 AM   #2
Vital
Drives: 2015 BRZ
Yes there is a whole thread on these shocks.
https://www.ft86club.com/forums/showthread.php?t=143629
Additionally i have them as well installed with my RCE Yellows and they are an awesome upgrade over the stock shocks. I would say it still rides firm and not jarring and bouncy as the stock shocks. It stays planted throughout corners, hardly any body roll and corner entry and exit definitely allow for much higher speeds than before. Its a worthwhile upgrade.
The Following User Says Thank You to Vital For This Useful Post:
Racecomp Engineering (06-17-2021)
Old 06-11-2021, 11:50 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I have B8s, same as B6 except less droop travel for lower springs (which isn't really necessary to keep springs captured even at 1.25" lower).
Great improvement over the factory PP/Sachs IMO, much smooover ride and I'd bet 20+mm more bump travel (important if lowered). Damping is fine street and track for me with 4.4 front 5.3 rear springs, should be fine for stock springs as well.
Old 06-11-2021, 12:04 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I have B6 paired with RCE springs. They're a solid upgrade over stock.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 06-12-2021, 11:13 AM   #5
billstock67
Drives: 2017 Toyota 86
I second the motion. Handles better, takes large bumps better.
billstock67 is offline   Reply With Quote
The Following User Says Thank You to billstock67 For This Useful Post:
Old 06-12-2021, 12:34 PM   #6
jflogerzi
jflogerzi's Avatar
If you don't want any adjustments you can't go wrong with the Bilstein dampers. Do yourself a favor and grab some RCE Yellows or swift springs.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 06-13-2021, 12:53 AM   #7
N_Raged
Drives: 2019 BRZ Sport-Tech RS
https://www.ft86club.com/forums/show...ostcount=19082
N_Raged is offline   Reply With Quote
Old 06-18-2021, 09:48 AM   #8
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
It's worth every penny!It should last about the same as the car itself & may even outlast the other coilovers. Paired with mild-drop lowering springs like RCE Yellow & TRD, the ride is planted, stiff but not harsh yet comfortable unlike stock.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 07-08-2021, 08:29 AM   #9
Jappy
Drives: Subaru 86
4wheelonline recommends Bilstein shocks. They're selling it for a fair price.
Jappy is offline   Reply With Quote
Old 07-08-2021, 11:26 AM   #10
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I have the B6’s with H&R springs along with Verus camber plates. The car just feels so solid. Between those things and heavier, adjustable sway bars I have the car to where I want it handling wise. Tires are NT01’s
TommyW is offline   Reply With Quote
FS: OEM Shocks brzt Brakes, Suspension, Chassis 1 06-07-2020 05:00 AM
Suspension Upgrade 2013 using 2016 shocks? JonnyQuest264 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-17-2016 09:14 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 09:31 AM
Upgrade Shocks - RSR Morimoto spec i sport coilovers vs RCE Tarmac 0/2 MaXimus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-21-2014 09:46 PM
