#197 | |
Drives: '13 FRS - STX
imho throw another half degree of camber at the front, I'm at -4.0 degrees, have been at -4.2 and have heard a few cars trying -4.5 and even -5.0. Everything else seems to be in the ballpark. |
#198 |
Drives: 2022 BRZ, Red
-4.5deg is resulting in a slight variation in wear across an A052 with more wear towards the inside for me. Not talking about too much though. I'll be dropping mine back towards the 4deg area to even out the wear. |
#199 | |
2013 Series 10 FRS #553
#200 |
Drives: 2013 BRZ Limited - stock
Redshift competition coilovers. They are revolved B.C Coil-overs…. Running 8k f/r. With perin end links
#201 |
Drives: 2016 Scion FRS
Wait, so you have toe in up front? Yeah, that doesn't help anything.
| The Following User Says Thank You to steverife For This Useful Post: | smg1138 (06-15-2021) |
#202 | |
Drives: 2013 Raven FR-S
#203 |
The alignment machine stated .05 toe ( I’m assuming that would be toe out and -05 would be toe in. Is this the correct assumption?. If that is the case . Would toe put help with turn in or harm it.
#204 | |
positive is toe in which helps in straight line stability and is what most road cars have because the average joe just wants to drive down the freeway without spilling their coffee but hurts turn in since you have to turn the steering wheel further to get more direction change. It's wonky but probably not helping you if it's actually toe-in. Edit: you have such a tiny amount of toe in at 0.05 degrees that I really don't think this is your root issue and changing it won't get you where you want to be if it's understeering enough for you to post on here instead of just band-aiding it with an air pressure tweak. |
#205 |
I have a question about spraying tires. I have Yokohama a052. I am attending the national tour event in Romulus N.y this weekend. Weather forecast is 80 each day. Slight chance for rain one day. Run in an old airfield paved with one section of concrete. First do you think spraying will matter with three runs, no co driver. 2nd. Do you spray side walls or tread, if so why. Thanks
#206 | |
Drives: 2017 BRZ series.yellow
#207 |
#208 |
#209 |
Most of your heat is coming from your brakes. I usually try to hit sidewalls first, then inside of the wheel as much as possible, then tread.
#210 |
I finally have a starting setup (of sorts):
- GReddy/KW V2 coilovers 6k/7k (336/392) - Karcepts front bar, full soft - RPF1 17x9 +35 - 255/40-17 RT660 - Camber 2.5F/1.8R (limited by the top hats) 1mm toe F/R Nothing fell off or made any strange noises on the test drive last night so I signed up for a local Saturday, we'll see how I do, it's been a while. --Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace Last edited by Autoxer62; 06-17-2021 at 02:35 PM. Reason: added photo |
| The Following 3 Users Say Thank You to Autoxer62 For This Useful Post: |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 11:27 AM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
