Old 06-16-2021, 05:43 AM   #1023
Kaotic Lazagna
Drives: GR Corolla
what? this makes no sense.. white led's are 3.2v ea. red led's are 1.9v ea... you should be able to run twice the amount of red led's over white...
what's your series/parallel wiring looking like?
Yeah, I don't get it either. I'm using a 2032 battery holder that has 2 positive terminals and 1 negative. The switch is a 4 channel switch.
So for the taillights, I have 4 LEDs with the positive wires leading to one wire that goes to the switch (channel 2), and then goes to the positive terminal of the battery holder. The negative wires lead to one wire that goes to the negative on the battery holder.
The headlights are wired the same way with the 2 LEDs. Positive wires lead to one wire that goes to channel 1 of the switch, and then goes to the other positive terminal. The negative goes to the same negative.
If I do the exact same set up as that with red LEDs for the taillights (which I did for the R33 and the Crown, the R34 I used two batteries and holders), I have that issue I mentioned earlier. Any idea on what's going on/what I'm doing wrong?
Old 06-16-2021, 04:22 PM   #1024
soundman98
ProCrastinationConsultant
soundman98's Avatar
try connecting series/parallel. of the 4 red led's at the back, split them into 2 groups.
connect the first group's first led positive wire to the positive wire from the switch. connect the negative of that led to the positive of the 2nd led, and then connect the negative of the 2nd led to the negative wire going back to the battery.
i suspect that all of the led's in parallel with the way you've wired them, you're reaching the limits of a cr2032 setup, as the voltage of a single 2032 works out ok, but it might be attempting to distribute too much of it across too many different area's.
Old 06-16-2021, 06:21 PM   #1025
Old 06-16-2021, 07:16 PM   #1026
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
African or European
Old 06-16-2021, 07:25 PM   #1027
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by FR-S2GT86 View Post
Am I posting this in the right thread?
Attachment 201481
Best laugh in a while.
100% right thread.
Old 06-16-2021, 08:15 PM   #1028
Kaotic Lazagna
Drives: GR Corolla
Would I put both groups to the same positive terminal and same channel on the switch?
I could always do what I did with the R34 and use two batteries and two holders. haha
Old 06-16-2021, 09:00 PM   #1029
Old 06-16-2021, 09:19 PM   #1030
soundman98
soundman98's Avatar
keep everything else as you had it. the rear lights on channel 2, the front lights on channel 1.
Old 06-16-2021, 09:42 PM   #1031
Watt is the internal resistance
Old 06-16-2021, 11:10 PM   #1032
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ohm-ygod tcoat, you can't just mix power and resistance units...
Old 06-17-2021, 05:43 AM   #1033
Kaotic Lazagna
Drives: GR Corolla
I'll try that on the next model. Thank you for the info!
Old 06-17-2021, 12:07 PM   #1034
Watts on second!
Old 06-19-2021, 10:33 PM   #1035
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Need modeling advice please . . .
I realize this is the *plastic* modeling thread but perhaps I might ask a metal modeling question? I drive a Halo 860 which has black stripes across the hood, roof, and trunk (see my avatar). I also have a 1/18 scale GT86 metal model in Halo - but no stripes. The real stripes are 5" wide at their widest which is .27" in 1/18 scale. I would like to add stripes to the model. What can I use for stripes that would be 1/4" wide and reasonably easy to work with? I thought maybe actual automotive black pin striping but is there any modeling alternatives? Thanks much!
LimitedSlip is offline   Reply With Quote
Old 06-19-2021, 10:41 PM   #1036
Hobby Lobby or any decent hobby shop sells black decal material that would work well for this.
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
