Old 06-15-2021, 03:04 PM   #1
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Going Flex Fuel
Hey Yall,
Back browsing the forums after an extended break in modifying my 2014 BRZ.
Been thinking recently about taking the leap to corn to produce a bit more power. Other than the bolt on exhaust and cold air intake currently installed purchasing a Flex Fuel kit, & an E-tune seems like the best “bang for my buck” as far as adding a few more horses under the hood.
A couple of questions I had for anyone with more knowledge on the subject / industry then me!
I have an Open flash tablet already, it would be nice to get a flex fuel kit that can be easy tuned using the OFT.
So, my first stop was OFT, I know they used to make a kit (and also have a sort of “off the shelf” tune for it) but it seems they are not making that kit anymore? Can anyone confirm? I know Shiv used to be a regular around here but I believe that activity has waned.
I see that Delicious tuning sells a kit labeled as an “OFT” kit, but as far as I can tell Open Flash requires you to be running the OFT kit to receive there off the shelf flex fuel tune. (That is not available) so I’d still need a custom E-tune from Open Flash that cost upwards of $300
Would it just be better to bite the bullet an go with Delicious’s EcuTek flex fuel tune?
VIP BRZ is offline   Reply With Quote
Old 06-15-2021, 04:12 PM   #2
alphasaur
friendly
Drives: 17' 86
Originally Posted by VIP BRZ View Post
Hey Yall,
I went with motoeast's flex kit including the ecutek. It was around $1200 I believe but you can recoup some cost from selling the OFT. There's certainly more support with ecutek.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-15-2021, 04:19 PM   #3
SexyPirates
SexyPirates's Avatar
I’m gonna be going with the ECUTEK from CSG when iI have enough saved up. Remote tuning from Zach seems to take a week or two to dial in.
SexyPirates is offline   Reply With Quote
Old 06-15-2021, 04:39 PM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
You can try E85 without a kit, you don't need flex fuel if your E85 is between 60 and 90% ethanol. You could be running E85 today
https://www.google.com/url?sa=t&sour...jF-uBV8ipsxIWh
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 06-15-2021, 06:42 PM   #5
Z06ZN6
Drives: 2017 Toyota 86
I went with the DT kit and their fuel safety option on my eforce 86 and an in-house dyno tune (SOCAL local like you). The fuel safety feature already saved my engine once from a pump failure a few weeks back. DT is great to work with and even over a year after tuning, Bill still replies to my emails within a few days.
Z06ZN6 is offline   Reply With Quote
Old 06-15-2021, 11:01 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
As @Purist said, you already have the OFT so just drive till your tank is close to empty, fill up with e85, flash the tune and enjoy the extra power with no extra expense
A flex fuel kit just adds convenience as far as not having to plan what fuel you'll fill up with. It doesn't add any power over a straight e85 tune, in fact it may well have less.
1974 TA22 Celica
2013 86 GT
Old 06-16-2021, 12:16 AM   #7
azeo
Drives: 2014 FRS Ultramarine
I did the OFT with e85 for awhile with no issues including on track. Just be sure to read the instructions thoroughly as you'll have to go through a learning process after each flash. The difficulty in switching back and forth is what drove me to get an actual flex fuel kit. Definitely give it a go though to be sure it's something you want.
Sent from my ONEPLUS A5010 using Tapatalk
azeo is offline   Reply With Quote
Old 06-16-2021, 02:02 AM   #8
Olson1288
Olson1288's Avatar
Drives: 2014 DGM BRZ Turbo
Nothing against Shiv, but many people have had some pretty terrible experiences with OpenFlash. I think he more or less gave up on the 86 platform to be honest. Ecutek is definitely the better option if you can swing it, but a bit more pricey. Also I've been running the FlexFuel kit from Delicious for 3+ years and never had an issue.
Olson1288 is offline   Reply With Quote
Old 06-16-2021, 02:04 AM   #9
DAEMANO
Time Traveller
Hey Yall,
I have a complete (never installed) Open Flash Flex Fuel kit for sale if you're interested DM me.
Old 06-16-2021, 02:07 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Community or other tuners (eg. Steve99 or Wayne) help with OFT case, if you use it (or tactrix) only as flashing device, not expecting much from OFT staff of actual work above available free OFT tunes.
Old 06-16-2021, 11:59 AM   #11
VIP BRZ
VIP BRZ's Avatar
This is honestly probably the best rout to go, like you all said I already have everything I need. Might as well try it out and see how I like it, no cost. Easy to switch back if I change my mind or upgrade to the flex fuel and get the custom tune.
I could even just skip the flex fuel & pay for an e-tune E85 specifically and squeeze a few more horse out of my bolt-on's ?
I'll send you a DM, I think I would have to have a receipt proving it was purchased from an authorized OTF dealer to be eligible for the free off-the-shelf flex fuel tune from Open Flash
Old 06-16-2021, 07:21 PM   #12
DAEMANO
Time Traveller
np, it was purchased directly from the official OpenFlash Performance website (not a dealer) so I have all the expected communications and proofs surrounding that.
Old 06-17-2021, 03:28 AM   #13
Purist
Purist's Avatar
Drives: Subaru BRZ
Can you provide evidence of this? People generally complain on forums about bad experiences...
Less More
Old 06-17-2021, 06:20 AM   #14
steve99
Drives: FT86
If you have oft id get the penguin tech racing flex kit for brz.
OFT compatavle flex tunes, fhe flex input signal must be via evap, no support for rear 02.
The oft flex kit have an issue with flex signal varing during cranking ive tuned a few, you can tune arround the kits issues but better to get penguin tech kit or a xero limits evap flex kit.
Can sort a flex tune for you for oft just message me
flex fuel kit
NEW OFT flex fuel kit & Flex Fuel Emblem Winmorgan77 Engine, Exhaust, Bolt-Ons 4 07-15-2019 09:29 AM
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
