Old 06-14-2021, 04:32 PM   #197
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Autoenthusiastasm View Post
Question on alignment. 8k for spring rate. -3.5 front, -2.5 rear. +.05 toe front. My car seems to push a bit on turn in. Is this a result of + toe, my 22mm sway. Too firm on my coil overs. Running on pavement. I had requested neutral toe, but the tech said this is recommended
I recently switched from 0 front toe to 1/16" toe out (similar to what you have) and I did not notice a significant change in balance.
imho throw another half degree of camber at the front, I'm at -4.0 degrees, have been at -4.2 and have heard a few cars trying -4.5 and even -5.0.
Everything else seems to be in the ballpark.
ineedyourdiddly
Old 06-14-2021, 04:48 PM   #198
Brock H.
Drives: 2022 BRZ, Red
...have heard a few cars trying -4.5 and even -5.0.
-4.5deg is resulting in a slight variation in wear across an A052 with more wear towards the inside for me. Not talking about too much though. I'll be dropping mine back towards the 4deg area to even out the wear.
Brock H. is offline   Reply With Quote
Old 06-14-2021, 06:48 PM   #199
jflogerzi
jflogerzi's Avatar
22mm in the front? What dampers and springs do you.
2013 Series 10 FRS #553
Old 06-14-2021, 11:05 PM   #200
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Redshift competition coilovers. They are revolved B.C Coil-overs…. Running 8k f/r. With perin end links
Autoenthusiastasm is offline   Reply With Quote
Old 06-15-2021, 09:53 AM   #201
steverife
Drives: 2016 Scion FRS
Wait, so you have toe in up front? Yeah, that doesn't help anything.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
smg1138 (06-15-2021)
Old 06-15-2021, 07:17 PM   #202
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
You definitely don’t want any toe in up front. I run zero front toe, but some people like a little bit of toe out for better turn in. Since I daily drive my FRS, I run zero as a compromise.
smg1138 is offline   Reply With Quote
Old 06-15-2021, 08:29 PM   #203
Autoenthusiastasm
The alignment machine stated .05 toe ( I’m assuming that would be toe out and -05 would be toe in. Is this the correct assumption?. If that is the case . Would toe put help with turn in or harm it.
Old 06-15-2021, 09:16 PM   #204
strat61caster
https://en.wikipedia.org/wiki/Toe_(automotive)
positive is toe in which helps in straight line stability and is what most road cars have because the average joe just wants to drive down the freeway without spilling their coffee but hurts turn in since you have to turn the steering wheel further to get more direction change. It's wonky but probably not helping you if it's actually toe-in.
Edit: you have such a tiny amount of toe in at 0.05 degrees that I really don't think this is your root issue and changing it won't get you where you want to be if it's understeering enough for you to post on here instead of just band-aiding it with an air pressure tweak.
ineedyourdiddly
Old 06-15-2021, 09:26 PM   #205
Autoenthusiastasm
I have a question about spraying tires. I have Yokohama a052. I am attending the national tour event in Romulus N.y this weekend. Weather forecast is 80 each day. Slight chance for rain one day. Run in an old airfield paved with one section of concrete. First do you think spraying will matter with three runs, no co driver. 2nd. Do you spray side walls or tread, if so why. Thanks
Old 06-15-2021, 09:31 PM   #206
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
I wouldn't spray the tires in those conditions. You shouldn't get anywhere near overheating the Yoks.
Breezio is offline   Reply With Quote
Old 06-15-2021, 09:47 PM   #207
Autoenthusiastasm
Thanks, just curious. Spray tread or sidewalls.
Old 06-16-2021, 09:25 AM   #208
Breezio
Breezio's Avatar
If/when you need to spray, I always spray the tread.
Old 06-16-2021, 10:01 AM   #209
steverife
Most of your heat is coming from your brakes. I usually try to hit sidewalls first, then inside of the wheel as much as possible, then tread.
Old 06-17-2021, 03:07 PM   #210
Autoxer62
I finally have a starting setup (of sorts):
- GReddy/KW V2 coilovers 6k/7k (336/392)
- Karcepts front bar, full soft
- RPF1 17x9 +35
- 255/40-17 RT660
- Camber 2.5F/1.8R (limited by the top hats) 1mm toe F/R
Nothing fell off or made any strange noises on the test drive last night so I signed up for a local Saturday, we'll see how I do, it's been a while.
--Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following 3 Users Say Thank You to Autoxer62 For This Useful Post:
PLX92 (06-18-2021), SCFD (06-17-2021), strat61caster (06-17-2021)
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
