Old 06-13-2021, 11:15 PM   #1
MINI135i
Ohlins R/T coilovers with larger front sway bar and STOCK endlinks?
We know that other threads have noted that there can be some interference issues with a larger front sway bar and "non-stock end links" that lead to breakage of the Ohlins end link mounting point.
I would like to know who is running Ohlins R/T coilovers, a larger front sway bar, and the stock endlinks with success?
If you have had success, which bar are you running with the stock end links?
Thanks
MINI135i is offline   Reply With Quote
Old 06-14-2021, 08:30 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just installed much bigger 25mm Ohlins front bar (and 19mm rear), with new stock endlinks. 1st track event on them this weekend...
Old 06-14-2021, 09:09 AM   #3
Racecomp Engineering
I think you're getting Ohlins and Eibach mixed up...
- Andrew
Old 06-14-2021, 09:34 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Actually just not recognizing he was looking specifically for larger sway bars with stock endlinks *with Ohlins coilovers*... So maybe not relevant...
Racecomp Engineering (06-14-2021)
Old 07-19-2021, 12:33 AM   #5
MINI135i
Anybody have further experience with the mentioned Ohlins set up in the original post?
Whiteline front sway bar + endlinks Mindsucker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 06-13-2017 03:40 PM
FS: stock front and rear sway bars with endlinks derpz86 Brakes, Suspension, Chassis 3 01-19-2016 06:58 PM
FS: D2 Coilovers with Whiteline sway bar endlinks - SOLD Road Pirate Brakes, Suspension, Chassis 4 12-23-2015 09:49 AM
Front Sway Bar endlinks D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-30-2012 04:14 PM
