Ohlins R/T coilovers with larger front sway bar and STOCK endlinks?
We know that other threads have noted that there can be some interference issues with a larger front sway bar and "non-stock end links" that lead to breakage of the Ohlins end link mounting point.
I would like to know who is running Ohlins R/T coilovers, a larger front sway bar, and the stock endlinks with success? If you have had success, which bar are you running with the stock end links? Thanks:) |
I just installed much bigger 25mm Ohlins front bar (and 19mm rear), with new stock endlinks. 1st track event on them this weekend...
- Andrew |
Anybody have further experience with the mentioned Ohlins set up in the original post?
| All times are GMT -4. The time now is 09:47 AM. |
User Alert System provided by
