Old 06-04-2021, 04:58 AM   #1
d0dlelczr37
Drives: White 86
Unexplained power cutoff
I am in a boosted e85 auto.
The car is 2015 Nov.
The problem is when you hold it at a high rpm and suddenly decide to floor it, the car will cut power. It is like a 2 step limiter where you bounce off a certain RPM which is not the red line. Not sure why that happens.
I notice that this happens when the torque converter is unlocked.
It has happened even I turned off traction control. And I don't think traction control will cut power by having an instant rev limiter at a certain RPM.
Does anyone have any clue?
d0dlelczr37 is offline   Reply With Quote
Old 06-04-2021, 08:23 AM   #2
Check your tune and log some data. With FI and E85 none of the stock parameters should mean anything.
soundman98 (06-05-2021)
Old 06-04-2021, 12:46 PM   #3
tomm.brz
Drives: brz 2017 hksv2
ecutek? probably boost limiter by ecutek closing throttle to 20%, need a log or kind of useless talking
Old 06-04-2021, 02:46 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Are you turning off traction control via the single button, or are you holding both buttons (VSC + TRAC) for 3-10 seconds? I would also do the pedal dance and then try to repeat your launch. If the symptoms persist then my guess is that there are some hard limits on your tune for boost, fuel pressure or some parameter that is causing throttle cut. Like others say, a log would be good.
Old 06-05-2021, 08:00 AM   #5
d0dlelczr37
Drives: White 86
Does anyone know what I should look for in the log?
My tuner would have access to the log but I need to be able to tell him what to look for.
Thanks in advance.
Also @Tcoat : what do you mean by stock parameters? @tomm.brz : Yes it is ecutek @Irace86.2.0 I turned off traction by holding it down. No paddle dance and haven't tried. Also when this happens, the traction light did not flash.
Old 06-05-2021, 09:15 AM   #6
Thanks in advance.
I meant the stock limiters and cut offs.
Old 06-05-2021, 09:41 AM   #7
d0dlelczr37
Drives: White 86
@Tcoat
What I have experienced is definitely not the new limiter. I know we lowered it to 7200ish and I have reached that rev at some point. What I have experienced is a cut off at around 5k, so it is definitely weird.
The Following User Says Thank You to d0dlelczr37 For This Useful Post:
Tcoat (06-05-2021)
Old 06-05-2021, 05:57 PM   #8
tomm.brz
don t you have a personal ecutek kit? you do not need your tuner to log, k xonnect your PC and just log, replicate the cut and post it
otherwise we can not help you in any way
Irace86.2.0 (06-05-2021)
Old 06-05-2021, 07:48 PM   #9
Irace86.2.0
If you don’t know how to log with ECUTEK then ask or look it up. It isn’t too hard. Try to replicate the power cut then post the log to Datazap or something and post here.
Old 06-05-2021, 10:53 PM   #10
d0dlelczr37
Drives: White 86
Ok, I will try to log it when possible. I don't have an ecutek kit, I think it is expensive to buy one and I got my turbo etc.. done with a tuner.
This is a video if it helps at all. At 4.5k rpm you can see the rev limit I talk about. In this video, it only occurred for half a second but in other times, it occurred for longer as if there is a rev limiter there preventing me to rev higher.
Old 06-06-2021, 01:36 AM   #11
tomm.brz
seems the ecutek boost limiter
bad tune
Old 06-06-2021, 01:49 AM   #12
Irace86.2.0
Does it do it in every gear?
Old 06-06-2021, 02:37 AM   #13
d0dlelczr37
Drives: White 86
It happens in second gear. But never tried for other gears because too fast for the roads.
Old 06-06-2021, 10:52 AM   #14
Irace86.2.0
In the video you are in 1st gear then it hesitates or loses traction around 4500 rpms and then it shifts to 2nd, and is the power cutting out or did you just let off the gas? I can't tell.
rev limiter / fuel cutoff clayrush Engine, Exhaust, Transmission 49 07-25-2017 11:40 PM
DIY OBD2/OFT Cutoff Switch LaertesSon DIY (Do-It-Yourself) Guides 5 04-24-2016 05:16 PM
4350rpm rev cutoff after car crash diodelphi Issues | Warranty | Recalls / TSB 9 02-26-2015 01:07 PM
Unexplained noises ap5512 Issues | Warranty | Recalls / TSB 1 02-13-2015 10:48 AM
Unexplained My Problem .... Now! 7thgear CANADA 17 01-31-2014 11:38 AM
