Old 06-03-2021, 07:49 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
You might try swapping tires front/rear and see if the problem changes or goes away. If so, could be a bad tire, it does happen.
They are all the same model tire, right? "Michelin 4s" meaning Pilot Sport 4S?
norcalpb (06-03-2021)
Old 06-03-2021, 08:18 AM   #16
Originally Posted by subaruslow View Post
They are all 4 michelin's I put on a new a year or so ago, the tire was not damage so it went back on once I got a new rim. Pressure's are all good.
To me it feels as if sometimes after a bump the car keeps undulating more than it should / use to. The back of the car is moving way more than it should.
Today after a spirited drive i have now developed an odd whirring sound at low speed, i'm definitely thinking there is something else other than alignment wrong now. Maybe I'll get lucky and the valvetrain will blow up and I can just light a match on the car while sitting in it.
things are not going well for me.
wheel bearing?
You hit a bump hard enough to bend a wheel and now you have a "whirring" sound? As said try moving the wheels around. If that changes it you may have broke some belts inside the tire. It could look fine but cause all sorts of weird things. If moving the wheels changes nothing then check out the wheel bearing on the one that hit. hey are another common cause of whirring noises. Oh and get the alignment checked.
Dadhawk (06-03-2021), norcalpb (06-03-2021)
Old 06-03-2021, 09:14 AM   #17
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
A poor alignment, left unchecked long enough, can cause other problems to crop up. I'm willing to bet you damaged something when you bent the rim that would've caused the alignment to go bad. Now you have problems in addition to that. @Tcoat is also spot on that an impact of that force could likely cause unseen damage. Whether it's on the tire or suspension, it could very well be there.
I'm surprised you chose not to get an alignment done when you got the tire put back on. Did you at least get it rebalanced? Getting both of those done at the time of the replacement would likely have caught any unseen problems. Any time you deal with rim or tire replacements you need to get those checked. It's not as simple as swap-and-go.
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
Old 06-03-2021, 10:04 AM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've had some pretty wonky alignments, never had it cause any problems other than weird handling and weird/excessive tire wear. It shouldn't cause any permanent problems.
Ultramaroon (06-03-2021)
Old 06-11-2021, 11:40 AM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Floating suggests the impact could have also blown the shock. The whirring noise could be wheel bearing but those are easy to check. With the car in the air, grab the wheel on each side (3 and 9 oclock) and try to move in/out - this will check play in the steering rack and lower ball joint, then grab the top and bottom of wheel and check for play which would be wheel bearing. You can also take off your brake rotor and spin the hub by hand and feel for any looseness of roughness (or lack of grease).
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Dadhawk (06-11-2021), Ultramaroon (06-11-2021)
Old 06-11-2021, 01:58 PM   #20
I would never have considered this! Purely due to lack of firsthand experience. Makes perfect sense.
Old 06-11-2021, 02:33 PM   #21
Annnnd
soundman98 (06-16-2021)
Old 06-15-2021, 06:49 PM   #22
subaruslow
Drives: subaru
Sorry for the delayed post. I do appreciate the help. So i'm embarrassed to say the noise seems to have been from the plastic protector in the front. It was rubbing the slightest bit. I still have not gotten in for an alignment yet only because things are so tight right now $. Oof. I am convinced there is still something funky as the traction goes off on the slightest bump and you hear a thud from the rear. I can't tell if the traction control coming on is contributing to it feeling wonky or not. Maybe it's applying rear brake when this happens?
Also for the record I was not in the car or the one piloting it when the rim was bent. I got to figure it out later...grrr The tire did get driven on a little bit when it was pretty low psi probably 18 so tire damage internally would not be out of the question, however the weirdness over bumps with the traction seems to be the rear. I know people get all crazy about small things with their car but to me It doesn't feel how it use to, it was never floaty like it is now. It definitely feels less stable if you are trying to drive at all spiritedly. I just want to get the car back and do a darned mines road trip or something, have some fun in it.
Thanks for the help guys. Next step will be alignment. I am trying to find somewhere that will be able to tell me if anything is bent. I don't know if it would be good to take it in to a place like racers line to see what they say?
subaruslow is offline   Reply With Quote
The Following User Says Thank You to subaruslow For This Useful Post:
Ultramaroon (06-16-2021)
Old 06-16-2021, 01:33 PM   #23
sharpsicle
sharpsicle's Avatar
Just an FYI, if you go to get a 4-wheel alignment done and anything is bent, they will not be able to properly complete the alignment and they'll tell you.
Old 06-16-2021, 02:20 PM   #24
Thanks for sharing. No shame. Shit happens. Talking about your experience helps all who come here for the big picture.
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 10:36 PM
Car feels better and more natural with hold traction off but why jflogerzi Tracking / Autocross / HPDE / Drifting 14 11-23-2020 02:09 PM
car feels funny after changing to summer tire/wheels theman233 Issues | Warranty | Recalls / TSB 4 04-02-2017 02:48 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 02:44 PM
First week off to a bad start, and a bunch on non-starts BCUZ BXR Issues | Warranty | Recalls / TSB 46 08-15-2013 08:04 PM
