Old 10-31-2013, 11:44 PM   #85
diss7
Drives: AE86, 2x GT86, TE27
Sounds like your missus likes you redlining your car.
diss7 is offline   Reply With Quote
Old 04-21-2014, 07:38 PM   #86
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
The smell I get isn't brakes or clutch, it smells more like differential fluid.
P86RAVES is offline   Reply With Quote
Old 04-21-2014, 08:04 PM   #87
wheelhaus
wheelhaus's Avatar
You could certainly check the diff for leaks. But also check the cam plate on the backside of the engine on the passenger side, it's about 5" tall and 2" wide. Use a paper towel and rub around the bottom edges to see if there is oil residue. You may also see some burned oil residue on the exhaust right below it. Do a search for the Raceseng cam plate to see more detail, they make a nice aftermarket plate for it.
Old 04-22-2014, 07:05 PM   #88
P86RAVES
It's definitely the diff fluid smell, but I have been looking at that plate and the problem it fixes. I have smelled the burning oil smell a few times and thought it may have been the cars in front of me as it would dissipate after they weren't around.
I'll have a look-see around my mechanical bits when I'm home during the daylight.
My nose is tuned for every automotive smell now, the only ones I have a hard time telling is brakes and clutch disc because they are sometimes the same material. Also ATF/PS for the same reason.
Old 07-03-2014, 03:19 AM   #89
Frozen_skidmark
Frozen_skidmark's Avatar
Drives: Whiteout FRS
It's crank case venting and blow by burning off at WOT. Do yourself a favor and pick up a catch can at least for the EGR side. It'll keep your engine clean and happy.
http://www.radiumauto.com/Catch-Can-...RZ86-P374.aspx
[ame="http://youtu.be/DZgwV8w1SNc"]http://youtu.be/DZgwV8w1SNc[/ame]
2014 Whiteout FRS
Frozen_skidmark is offline   Reply With Quote
The Following User Says Thank You to Frozen_skidmark For This Useful Post:
TofuJoe (07-10-2016)
Old 02-17-2016, 10:28 PM   #90
zberz
Drives: 2015 Lightning Red BRZ
Only about 4 years late, but my '15 BRZ is leaking oil at the filter under high RPM and it's causing a horrible smell. Not enough to worry about the level (check it often), but enough to burn and smell. Hoping it's a bad filter, been too cold for an oil change.
sent from my phone using black magic
zberz is offline   Reply With Quote
Old 02-18-2016, 02:38 PM   #91
shellslinger
Might want to look into it. It may be as simple as your oil filter or something similar to a timing chain cover oil leak.
shellslinger is offline   Reply With Quote
Old 05-31-2021, 09:07 PM   #92
RippedManiac
Jedi
Drives: Pikachu BRZ
I had a timing cover leak that was slowly sweating oil out. The smell was oil burning off the header.
RippedManiac is offline   Reply With Quote
how do you remove odor from fabric? prest1ge Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 07-03-2012 09:45 AM
Australia - Confirmed Details & Strong Rumours Netrosis AUSTRALIA 81 05-22-2012 11:22 PM
How strong is tranny? theaero Engine, Exhaust, Transmission 14 04-27-2012 08:51 AM
What you want under the hood of a higher performance OEM variant of the AS1? MrVito BRZ First-Gen (2012+) — General Topics 26 12-27-2011 12:07 AM
Can someone do a chop with the hood 5cm higher as described in the Autocar interview? devtec FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 37 06-08-2010 01:11 AM
