Old 05-27-2021, 05:12 PM   #1
Khal1d__
Drives: BRZ - GReddy Turbo T518z
Engine Rough idle and cursing sometimes
Engine Rough idle and cursing sometimes it is normal some time rough again i check the fuel pressure, map and maf sensor all constant reading but still rough
Khal1d__ is offline   Reply With Quote
The Following User Says Thank You to Khal1d__ For This Useful Post:
humfrz (05-27-2021)
Old 05-27-2021, 05:55 PM   #2
saltywetman
Drives: 2020 Toyota 86 GT 6M
any error codes? what do you mean when you say cursing? i've never heard of an engine dong that.
saltywetman is offline   Reply With Quote
The Following User Says Thank You to saltywetman For This Useful Post:
humfrz (05-27-2021)
Old 05-27-2021, 06:13 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
must have some pissed off crickets :O
HKz is offline   Reply With Quote
The Following 4 Users Say Thank You to HKz For This Useful Post:
MJones_RB (06-01-2021), Purist (05-27-2021), soundman98 (05-28-2021), spike021 (05-27-2021)
Old 05-27-2021, 11:59 PM   #4
Welcome to the group, there, Khal1d____ -
As @saltywetman asked:
* What is cursing (you or the engine) ? -
* Is the engine throwing any codes? If so, what codes?
How many miles/kilometers on the spark plugs?
Have you had any previous problems with the coil packs?
Come back.
Old 05-28-2021, 12:14 AM   #5
Khal1d__
Come back.
i ment cruising
no there no codes now, before i month it give fuel rail pressure low put nothing now. i have an air fuel ratio gauge it go rich then lean. i change the plugs in about 40K. and no problem with the coils
humfrz (05-28-2021)
Old 05-28-2021, 12:31 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
your car has a turbo? have you talked to your tuner to make sure that nothing with the tune needs to be adjusted?
do you have the datalogs?
humfrz (05-28-2021)
Old 05-28-2021, 07:49 AM   #7
Engine cursing sometimes
Turboettes?
bcj (05-28-2021), x808drifter (05-28-2021)
Old 05-31-2021, 01:39 AM   #8
jflogerzi
jflogerzi's Avatar
Mileage? Coil and spark plug age?
2013 Series 10 FRS #553
Engine Stalled, Rough Idle And Knocking Noise On Startup Slade Issues | Warranty | Recalls / TSB 49 09-28-2020 10:13 AM
Rough Idle DeathToocher Engine, Exhaust, Transmission 18 03-20-2020 10:45 AM
Engine running rich, stumbling, rough idle after motor swap toyubie Engine, Exhaust, Transmission 19 04-07-2018 12:11 PM
Took my car in for rough idle... Da Brz Issues | Warranty | Recalls / TSB 34 10-29-2016 12:57 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
