Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Transmission and Driveline
Old 05-12-2021, 01:42 AM   #1
AxisPower
Drives: 23 GT4RS
SOLD Trd close ratio gear set 1-2, mfactory 6th gear SOLD
SOLD
AxisPower is offline   Reply With Quote
Old 05-27-2021, 03:29 AM   #2
tian105
Drives: M4
Originally Posted by AxisPower View Post
https://www.trdparts.jp/manual_pdf/86/33030-ZN630.pdf
2.946 1st, 2.011 2nd and mfactory 0.861 6th gear. 1500 shipped in the continental USA
Does this make 1st and 2nd gear longer or shorter?
tian105 is offline   Reply With Quote
Old 05-27-2021, 12:19 PM   #3
AxisPower
Drives: 23 GT4RS
1st and 2nd will be spaced closer together and closer to third than stock. Essentially, rpms will be lower at the same speed as the original gears. The mfactory 6th gear will bring the ratio closer to 5th therefore the rpms will be higher at the same speed as the original gear. I guess this would make these gears shorter since it brings them closer together with a smaller rpm drop when shifting compared to the original ratios.
Take a look at this cusco pdf, since its essentially the same gearset just rebranded:
https://www.cusco.co.jp/en/jpg/86%20BRZ%20Gears_A4.jpg
Old 08-01-2021, 05:35 PM   #4
tian105
Drives: M4
Did you ever have it installed? If so, can you hit 60 in 2nd?
Old 08-02-2021, 11:31 AM   #5
AxisPower
Drives: 23 GT4RS
I had the 1-2 gearset installed but not the 6th gear. You can definitley hit 60 in second before redline, this is with a 4.1 final drive.
Old 08-02-2021, 06:27 PM   #6
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
4.1 RATIO DIFF
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 10-22-2021, 08:23 PM   #7
AxisPower
Drives: 23 GT4RS
Bump. Lowering price to 1300 shipped in the USA.
Old 05-16-2022, 08:30 PM   #8
AxisPower
Drives: 23 GT4RS
bump
Old 08-02-2023, 10:41 AM   #9
AxisPower
Drives: 23 GT4RS
bump, still got this
Old 10-21-2023, 07:23 PM   #10
AxisPower
Drives: 23 GT4RS
Bump, 1000 shipped, not looking to ship overseas or any forwarding addresses thanks.
Old 03-14-2024, 10:37 PM   #11
AxisPower
Drives: 23 GT4RS
bump
Old 08-17-2024, 07:45 PM   #12
AxisPower
Drives: 23 GT4RS
bump
Who wants a TALLER MFactory 6th gear toast Engine, Exhaust, Transmission 41 10-05-2020 03:12 PM
BRZ 2018 AT to MT gear ratio Septor Engine, Exhaust, Transmission 22 01-21-2019 04:42 PM
MFactory Final Drives & Close Ratio Gears YCW Transmission and Driveline 0 09-29-2016 01:28 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
