Old 05-25-2021, 05:15 PM   #78065
Jordanwolf
Rice King
Jordanwolf's Avatar
I suppose it could be, but I have seen it in other cases. I've deleted a few but it's usually in something like "Counting with Pictures" or "Keep a word, drop a word" where someone snipes my entry and it's out of order.
This is true. It just has me pretty curious that I've seen a lot of them lately. Got some delete post bandits here now.
Glorious Honda.
Jordanwolf is offline
Old 05-25-2021, 05:24 PM   #78066
spike021
spike021's Avatar
The cat is more likely to fail when running an SC. Less of a risk with the front pipe cat but still a potential issue. I know of someone who lost a FP cat running the jackson racing setup. Play at your own risk.
Also as someone who had a catted JDL UEL (though second owner), its cat also blew even though both me and the previous owner were NA.
Supposedly the newer ones from JDL have higher-rated cats meant for FI applications, but I don't really know how scientifically accurate that is and if it really means they'll last longer.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
NoHaveMSG (05-25-2021)
Old 05-25-2021, 05:25 PM   #78067
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Jordanwolf View Post
How come I keep seeing "Deleted post" in my notifications.
You see that if someone quotes you then later deletes their post. Not sure if it does the same for "Thanks".
It should be a member deleting the post or even mods or admin deleting the posts/threads.
I can tell you, today have been peaceful day here. I haven't done much work...
ichitaka05 is offline
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
Dadhawk (05-25-2021), soundman98 (05-25-2021), spike021 (05-25-2021)
Old 05-25-2021, 05:27 PM   #78068
Jordanwolf
Rice King
Jordanwolf's Avatar
Time to stir up some shit.
Glorious Honda.
The Following 6 Users Say Thank You to Jordanwolf For This Useful Post:
Dadhawk (05-25-2021), ichitaka05 (05-25-2021), soundman98 (05-25-2021), spike021 (05-25-2021), Spuds (05-25-2021), therealstoly (05-25-2021)
Old 05-25-2021, 05:28 PM   #78069
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I have one the newer ones, but its seems to be discontinued as of this moment . I know they we’re having supply issues and what not.
spcmafia is offline
Old 05-25-2021, 05:33 PM   #78070
spike021
spike021's Avatar
Dang, that sucks since if I ever go flex fuel again I probably would want to get a new header, and that's the one I preferred.
spike021 is offline
Old 05-25-2021, 06:10 PM   #78071
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Pro Tip!
If you don't want Mod/Admin to see your deleted post, change it to something like "...", save it, go back into it and then delete it. That will delete ... as the deleted post instead of what you originally typed. They can see whatever you delete.
Conversely, if you want to add pertinent info to a thread/post you're going to report, as an example, you can type out a post, go back into it, delete it and only Mod/Admin will be able to see what you typed. Was a relatively popular means of communicating with Mod/Admin on a forum I ran. Someone would post up links, examples, threads, etc., delete the post from the pubic, report the thread and put something like "see my deleted post for info" as the reason, and we could see additional info that the public couldn't. Helped a lot in running a busy forum with limited unpaid staff.
therealstoly is offline
The Following User Says Thank You to therealstoly For This Useful Post:
Old 05-25-2021, 06:16 PM   #78072
Jordanwolf
Rice King
Jordanwolf's Avatar
Originally Posted by therealstoly View Post
Pro Tip!
I do believe on some forums there also exists a form of html/css/php injection that would make a post invisible just like you describe with deleting.
Glorious Honda.
Old 05-25-2021, 06:20 PM   #78073
pope
has a funny hat
Drives: 2014 BRZ Limited
Pro Tip!
As an non-mod I can not confirm, but it is my understanding from discussions with mods that they can view the full edit history of every forum post, so the "..." trick doesn't work here.
pope is offline
Old 05-25-2021, 06:26 PM   #78074
For any doubters!
See? I fit just fine.
Ultramaroon is offline
Tcoat (05-25-2021)
Old 05-25-2021, 06:33 PM   #78075
the steering wheel was basically up against my groin.
that's how I like it
spike021 (05-25-2021), Tcoat (05-25-2021)
Old 05-25-2021, 07:09 PM   #78076
ichitaka05
Site Moderator
ichitaka05's Avatar
Anyone here buy digital version of Hyper Rev? I don’t need to go on back end DL for free or anything… well if I can it for free it would be nice, but buying it is fine. Just prefer digital version.
Old 05-25-2021, 07:35 PM   #78077
The deleted posts thing is relatively new. I get them all the time and it is always where a whole thread is deleted by a mod/admin. Usually is some spambot thread that I said "reported" in or where we played before it got deleted.
Tcoat is offline
Jordanwolf (05-25-2021), soundman98 (05-25-2021)
Old 05-25-2021, 07:47 PM   #78078
You took 20 minutes to get in and almost an hour to get out again.
Watching Ho's face was almost as much fun as you trying to get out!
"Oh it is easy to get out just flop your leg over the sill and push"
"Remember you can't pull on the door"
"Don't grab the roof"
"NO don't push on the steering wheel"
"Put you hand down there and push"
"NOT THERE OVER THERE"
NO DON"T GRAB THAT"
Tcoat is offline
NoHaveMSG (05-25-2021), soundman98 (05-25-2021), Spuds (05-25-2021), therealstoly (05-25-2021), Ultramaroon (05-25-2021)
