Old 05-25-2021, 03:43 PM   #78051
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
It let's you sense magnetic fields. Is there a reason for it in a society where none has that sense anyway? No. But it's a sense you otherwise wouldn't have. There are animals that can sense magnetic fields naturally.
I think the NFC chip sounds more useful, but until we have cellphones in our heads it's kind of redundant. Think about exchanging contact info with a handshake. Or not needing a key fob at all, just program your car to recognize your NFC signature.
Yeah, implanting NFC make more sense than magnet.
ichitaka05 is offline
Spuds (05-25-2021)
Old 05-25-2021, 03:44 PM   #78052
spike021
spike021's Avatar
NFC on its own probably wouldn't be secure enough still.
My guess is something like NFC+Apple's "Secure Enclave" or whatever other companies are doing that's similar. A highly secure SOC that can handle keeping that data authenticated/validated.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
Spuds (05-25-2021)
Old 05-25-2021, 03:45 PM   #78053
spike021
spike021's Avatar
For any doubters!
I wasn't much far off, myself.
Actually, I don't know which was worse. That or getting into the track-prepped MX5 at Thunderhill that had a bucket seat several sizes too small for me, or:
This bucket was tiny-person sized. I was able to "get in" but the steering wheel was basically up against my groin.
spike021 is offline
The Following 3 Users Say Thank You to spike021 For This Useful Post:
soundman98 (05-25-2021), Spuds (05-25-2021), Ultramaroon (05-25-2021)
Old 05-25-2021, 03:48 PM   #78054
I think what it really does is let you feel a magnetic field trying to pull the magnet out of you, but I suppose that's semantics.
It's an odd thing I've read some on before, but hey whatever vibrates your magnatron I guess. There was a linked article about someone embedding basically what was a credit-card size rasberry pi under their forearm to send biometric data to the Internet.
It takes all kinds.
Dadhawk is offline
NoHaveMSG (05-25-2021), spike021 (05-25-2021), Spuds (05-25-2021)
Old 05-25-2021, 03:59 PM   #78055
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes, that is the limitation. The benefit of NFC is the power source is the initiating terminal, meaning you don't need one on the service consumer side. But, there is only so much you can do on the consumer side because of power limitations. So you need an embedded smartphone equivalent to make it work. And how many of us are really comfortable putting a cellphone battery under our skin... Or a GPS tracking device... Or...
Spuds is offline
soundman98 (05-25-2021), spike021 (05-25-2021)
Old 05-25-2021, 04:03 PM   #78056
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I was roaming around the forum and ran into Irace86's Kswap thread, which sent me down the rabbit hole, not about K-swapping, but his Harrop supercharger. I can absolutely not afford it right now, but is like when I used to go to CarID, fill the cart with all these fancy parts, go to checkout, delete all items in the cart, and then cry myself to sleep.
Which brings the question, to humor me, would the catted JDL UEL/ or my whole exhaust setup be compatible with a Harrop SC.
Damn you Irace......jk. Best of luck with your build.
spcmafia is online now
Old 05-25-2021, 04:18 PM   #78057
You may have missed this thread....
Dadhawk is offline
spcmafia (05-25-2021)
Old 05-25-2021, 04:22 PM   #78058
spcmafia
spcmafia's Avatar
Oh I did see it lol, I watched in amazement with the aftermath pictures. But he was creating a hell of a lot more power than I will ever want.
The Following User Says Thank You to spcmafia For This Useful Post:
Dadhawk (05-25-2021)
Old 05-25-2021, 04:39 PM   #78059
Jordanwolf
Rice King
Jordanwolf's Avatar
How come I keep seeing "Deleted post" in my notifications.
Glorious Honda.
Jordanwolf is offline
Old 05-25-2021, 04:54 PM   #78060
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The cat is more likely to fail when running an SC. Less of a risk with the front pipe cat but still a potential issue. I know of someone who lost a FP cat running the jackson racing setup. Play at your own risk.
NoHaveMSG is offline
Old 05-25-2021, 04:58 PM   #78061
You see that if someone quotes you then later deletes their post. Not sure if it does the same for "Thanks".
Dadhawk is offline
Old 05-25-2021, 05:00 PM   #78062
Jordanwolf
Rice King
Jordanwolf's Avatar
You know what, I've never actually tried to delete a post before.... I don't know why, but I was thinking it was getting deleted by a mod LOL
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
Old 05-25-2021, 05:07 PM   #78063
I suppose it could be, but I have seen it in other cases. I've deleted a few but it's usually in something like "Counting with Pictures" or "Keep a word, drop a word" where someone snipes my entry and it's out of order.
Dadhawk is offline
Jordanwolf (05-25-2021)
Old 05-25-2021, 05:15 PM   #78064
spcmafia
spcmafia's Avatar
I have a double resonated FP so I think that would be okay. As far as the header goes, JDL claims it can handle 500HP/ build for turbo and boost because of the GESI cat. I’ve just never seen someone actually putting it to test.
