Old 05-20-2021, 04:15 PM   #1
Stefforegaz18
Drives: Subaru BRZ 2014
Exclamation Subaru BRZ strange squeal/screeching noise while accelerating/decelerating
Hi all! I'm new in the forum and this is my subaru BRZ from 2014. I have tried to search everywhere to find if someone had this problem but I didn't find anything about it.
As you can hear, there is a strange noise, something that is screeching in the engine bay.
I have tested the car these days and it's seems like the sound comes out after strong acceleration, like hitting 7000 rpm, but it's pretty random; if i drive under 6000 rpm it won't happen (at least it seems).
This is not related to the clutch; it can be engaged or not, the sound still remains if it comes out.
Also, it lasts for like one minute or two, then it disappears.
I haven't CEL and the car still runs very good even if this squeal is on.
You can hear it in the first rev and in the third pretty clearly.
Hope this will help:
Thanks to everyone who will reply
Stefforegaz18 is offline   Reply With Quote
Old 05-22-2021, 01:21 AM   #2
Hello Stefforegaz18 and welcome to our forum -
Personally, I can't hear anything on your video. Maybe because my ears are too old -
How many miles on your car?
Do you have any engine modifications?
The first thing I would suspect is the serpentine belt. It may be wore out (slipping). You could either put some belt dressing on it or replace it.
Also check the idler pulley. Make sure it's not wobbling or dry.
Others will be along soon with some other ideas -
Old 05-22-2021, 02:40 AM   #3
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
I hear a rattle but not a screech ......
mswbrz is offline   Reply With Quote
Old 05-22-2021, 06:41 AM   #4
Stefforegaz18
My car has 62000 miles, It has been mapped by the previous owner and it mounts a Militek catback exhaust (with empty muffler, I don't know if I translated it correctly).
Anyway, I have to go to the dealership in the next two weeks, so hopefully they can identify this sound.
I'll make another video where this sound does not appear, in orther to compare it with the previous video.
The Following User Says Thank You to Stefforegaz18 For This Useful Post:
humfrz (05-22-2021)
Old 05-22-2021, 06:45 AM   #5
Stefforegaz18
Maybe It's the Militek exhaust but I thought it was just the engine revving up, a normal sound.
I bought this car with the militek already mounted so I'm not that used to with the stock sound.
Old 05-24-2021, 12:27 AM   #6
jrhudson
Drives: 2016 scion frs
Yeah, I don't hear a screech of any kind. Sounds like subtle rattle at the beginning and later on. But it sounds like an exhaust or maybe a non issue, I believe it's a small problem or something that doesn't need to be touched. or for piece of mind, I'm the same way, do says @humfrz change the accessory belt, that's cheap and easy.
jrhudson is offline   Reply With Quote
The Following User Says Thank You to jrhudson For This Useful Post:
humfrz (05-24-2021)
Old 06-04-2021, 05:59 AM   #7
Stefforegaz18
So anyway, I have been to the dealership and they told me that the "problem" is probably related to the VVT system on the right side of the engine (looking in front of it). They said that right know I do not have to be worried about it, also because there's no any check engine light on.
If I've got any new problems I'll update the topic.
Thanks for all the replies!
Screeching noise from engine kyoshi11 Issues | Warranty | Recalls / TSB 35 04-14-2023 12:50 PM
Crunching Noise When Decelerating In 2nd/3rd idkwhatimdoing Issues | Warranty | Recalls / TSB 37 01-10-2018 10:30 PM
BRZ strange screeching noise TOLM Issues | Warranty | Recalls / TSB 13 12-20-2017 12:26 AM
Brief Scratching/squeal sound. Accelerating/change gears. resli Issues | Warranty | Recalls / TSB 13 03-02-2016 01:56 AM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 04:37 PM
