Old 10-15-2020, 04:55 AM   #1
kyoshi11
kyoshi11's Avatar
Screeching noise from engine
My engine started to screech at idle and when I start moving from a stop light. I have a 2014 AT BRZ 34K miles. I took it to the dealer and they said they could not hear anything...
This is the link to a video of my engine at idle making the noise. Does anyone know a fix for this? I just replaced my serpentine belt and it still makes the noise.
kyoshi11 is offline   Reply With Quote
Old 10-15-2020, 05:39 AM   #2
kev0
Drives: '14
If it's not the belt then it could be one of the pulleys. Take the belt off and try spinning them by hand.
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
humfrz (10-15-2020)
Old 10-15-2020, 01:06 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is your car stock? It sounds more like a heat shield to me. Definitely not belt, but potentially a pulley.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (10-15-2020)
Old 10-15-2020, 01:18 PM   #4
humfrz
Sounds like a wounded cricket -
Seriously, I suggest you put a homemade stethoscope around the engine parts to see if you can isolate where the sound is coming from.
sato (10-17-2020)
Old 10-15-2020, 06:08 PM   #5
kyoshi11
kyoshi11's Avatar
I just took the belt off and all the pulleys spin except the crank pulley
Old 10-15-2020, 06:09 PM   #6
kyoshi11
kyoshi11's Avatar
i have intake, headers and cat back
Old 10-15-2020, 06:50 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Open the hood while it's doing this at idle and you might better locate where it's coming from. It's something that's spinning and not lubricated by the sound of it. Possibly a bearing somewhere.
Is it higher pitched or louder when revs are above idle?
This might be one where the only way to know it when the component eventually fails.
Old 10-15-2020, 07:03 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
I agree that it sounds like something vibrating, rubbing.
NoHaveMSG (10-15-2020)
Old 10-15-2020, 07:09 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check the header to over pipe connection, and the over pipe to front pipe connection. Also check the heat shield on the over pipe.
Old 10-15-2020, 08:03 PM   #10
kyoshi11
kyoshi11's Avatar
it is higher pitched and it mainly happens when AC kicks in but sometimes makes the noise when im not running AC if that helps...
Old 10-15-2020, 08:07 PM   #11
kyoshi11
kyoshi11's Avatar
will do, thanks
Old 10-15-2020, 08:21 PM   #12
Ultramaroon
not playing cards
We hear it. Do what @wbradley suggests and notice the specific way the engine rocks a bit more when the AC kicks in. The engine is chugging a little to do that work. Get in there and listen while a helper taps on the throttle. Might need to get underneath to listen but you'll find it.
Old 10-15-2020, 08:26 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And be careful around rotating parts. Sleeves, scarfs, masks, hair, hands. I have seen enough gruesome injuries from that shit in my industry to make me paranoid of anything that spins under force
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (10-16-2020), humfrz (10-16-2020), norcalpb (10-15-2020), pope (10-15-2020), Ultramaroon (10-15-2020)
Old 10-15-2020, 08:44 PM   #14
Ultramaroon
not playing cards
+1 for sage advice.
NoHaveMSG (10-16-2020), norcalpb (10-15-2020)
engine issue, heat shield, problem
BRZ strange screeching noise TOLM Issues | Warranty | Recalls / TSB 13 12-19-2017 11:26 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 03:37 PM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 12:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 06:39 AM
metalic screeching turning left raptor87 Issues | Warranty | Recalls / TSB 2 01-18-2013 01:41 PM
