Old 05-21-2021, 11:06 AM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
Knockoff coil packs
Has anyone tried non-oem coil packs? Do they have a shorter lifespan than the OEM parts?
Normally an OEM part is the path I would take here but as fast as they go out I'm wondering if having a NEW knockoff is better than a used OEM part in this case.
Ebay Coilpacks
Even cheaper
redlined600 is offline   Reply With Quote
Old 05-21-2021, 11:26 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I dunno about those cheap ones. I am running an NGK coil pack in my car that was about 65 bucks I think. It has been good for quite a few years.
Old 05-21-2021, 08:34 PM   #3
jflogerzi
jflogerzi's Avatar
Ebay Coilpacks
Even cheaper
Look for used OEM ones. Got 2 for 90$ shipped. Why are you changing them? unless your throwing codes or are really high milage no need to change. My 2 cents
2013 Series 10 FRS #553
Old 05-24-2021, 01:18 AM   #4
dreamwonder
Drives: GR86 2022
I use to replace oem coilpacks often, like every 6 to 8 ish track days. Till I bought some eBay ones...forgot what they are but it's blue. 40+ days so far still no issues. This is on a 2013.
dreamwonder is offline   Reply With Quote
Old 05-24-2021, 01:21 AM   #5
dreamwonder
Drives: GR86 2022
Looked it up.
Benchmark Legacy 2.0 FA20 Performance Ignition Coilpacks FK0438 Full Set 2015>
Old 06-02-2021, 11:26 AM   #6
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Originally Posted by dreamwonder View Post
Looked it up.
May have to try these.
I had the idea to switch to the 2015+ coils using the ice fab pigtails or buying the parts separately. Would still have to add the price of coils on top of these connectors.
https://www.icefabrication.com/produ...grade-to-2015/
Shneegle is offline   Reply With Quote
Old 06-02-2021, 04:06 PM   #7
redlined600
Drives: Fr-s
Were you able to find these for the 2013-2014? Ebay only lists the 2015+
Old 06-03-2021, 10:10 AM   #8
dreamwonder
Drives: GR86 2022
Oh yea, I recall now. It was the wrong connector, so I texted the guy and he sent me the ones with the correct connector for a 2013 FRS. Maybe text the ebay seller and see what he can do.
Seller: we-want-great-feedback
Price paid for 4: $170
Old 06-03-2021, 10:44 AM   #9
thekevinvo
Drives: 2014 Scion FRS
Off the Line Performance just recently released their OTL Street Series Ignition Coils that I would call an OEM+ replacement. They're not going to be as cheap as the ebay ones, but they're less expensive than the OEM ones.
They've sent me a set that I'm going to test out on my track car. They're supposed to output 10% more power as well.
thekevinvo is offline   Reply With Quote
Old 06-07-2021, 10:03 AM   #10
Shneegle
Shneegle's Avatar
Used my last replacement coil at the track this past weekend. So I found the listing for the 2013-2014 coils and ordered a set. Same seller as dreamwonder, they sent a PM to confirm the connector type. Price was $172+shipping.
Old 06-07-2021, 12:32 PM   #11
renfield90
The Stig's German cousin
At Spring Nats we used whatever generic part we could get from Napa to replace a failing coil. It was less than $120 after tax. No idea how good the part is but it appears to generate spark at the appropriate time.
Old 10-08-2021, 10:11 PM   #12
Shneegle
Shneegle's Avatar
Well its been about 4000 miles and the coil from cylinder 1 is failing. I've contacted the seller so we will see what happens.
Old 10-08-2021, 11:29 PM   #13
redlined600
Drives: Fr-s
These were the blue benchmark coils mentioned above?
Old 10-15-2021, 11:03 PM   #14
jflogerzi
jflogerzi's Avatar
I don't see them on the site. I have killed my second coil same one cylinder 1. How have they held up? Thinking of just getting OEM one and wrap some gold tape to help keep some heat out
Sent from my Pixel 5a using Tapatalk
coil packs Replacements OEM or Aftermarket jflogerzi Tracking / Autocross / HPDE / Drifting 76 10-05-2022 08:47 PM
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
2013 Coil Packs, where did you guys get them from? Keenercarguy Issues | Warranty | Recalls / TSB 24 05-25-2018 08:43 PM
Stock 13/14 coil packs shaynek Want-To-Buy Requests 1 04-26-2018 08:20 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
