Old 05-18-2021, 10:20 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Fuel starvation, verus flap?
I got fuel starvation at 7/8 tank at New Hampshire Motor Speedway (chicane/chicane) couple of weekends ago, coming out of T6/T7 (6 is a heavily banked 180 degree left-hander that blends into 7, also left). Is the Verus flappy door the preferred cheap-and-easy fix? Palmer coming up June 19/20, it's the only place I've had fuel starvation before, and that was at just under 1/2-tank. With apparently grippier tires this year (Nankang CR-1) I'd like to be able to run at 1/2-tank, or at least 3/4 without running into this issue after extended turn 1-2 left-hander...
Old 05-18-2021, 10:37 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It helps a lot, especially on an NA car. I used to get fuel starve on this long decreasing radius left, now I don't at even low fuel levels.
Old 05-18-2021, 11:01 AM   #3
fminicooper
Drives: FRS Hot Lava
worked for me like a charm. NA engine, starving on long left quick turn @msRH.
check filling full full the tank if you properly reseal the tank.
fminicooper is offline   Reply With Quote
Old 05-18-2021, 11:40 AM   #4
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
As another data point, I just received my Verus Fuel Door. I too had fuel starvation issues while less than 3/4 tank on 245/40/17 A052's. I'm honestly surprised more people don't have issues, but I guess it's a function of G-force which may only be achievable on certain tracks/setups. Will update here with my results.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 05-18-2021, 03:30 PM   #5
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
It helps but won't fix your issues. At one of my local tracks without the flap I'd get fuel cut at 1/2 a tank or less on 200tw tires, with the flap I can go down to about 1/3rd of a tank before fuel starve. For me, that's worth it since it means I can do 2x20min sessions before refueling instead of needing to top off after every session.
14stu is offline   Reply With Quote
Old 05-18-2021, 04:50 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
If it allows me to keep on trucking to 1/2, 5/8, or even 3/4 of a tank, it'll be worth it vs. starvation at 7/8...
Old 05-18-2021, 06:29 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Flap ordered, thanks fellas!
Old 05-18-2021, 11:19 PM   #8
jflogerzi
jflogerzi's Avatar
Maybe replace oem pump with a stronger aftermarket pump. How old is the oem pump. Your in there might as well just in case you decided to goto more power or boost
2013 Series 10 FRS #553
Old 05-19-2021, 07:22 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
it's a 2017, not too worried about the fuel pump. I'd be more likely to get a new 2.4 and go from there rather than boost the 2.0, I think... Any case I'll put other possible upgrades until I needs em.
Old 05-19-2021, 12:47 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The issue is the fuel runs out of the fuel basket on left turns where the fuel pump is housed. The only real 100% fix is to go to a swirl pot.
SAVAGE! Autoworks fuel starvation flap $55 Ashikabi Engine, Exhaust, Bolt-Ons 0 10-24-2020 09:10 AM
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-28-2018 11:47 PM
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 03:22 PM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 11:19 AM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
