View Poll Results: How would you rate the design of the 2nd gen 86? 1 lowest & 5 highest
1 10 3.80%
2 19 7.22%
3 49 18.63%
4 114 43.35%
5 71 27.00%
Voters: 263. You may not vote on this poll
Old 05-17-2021, 06:33 PM   #533
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by dave11 View Post
It sure looks a lot like the 370Z.
Yep, 4 wheels, 2 lights on each end, intakes in the front and exhaust in the back. identical.
The Following 8 Users Say Thank You to Yoshoobaroo For This Useful Post:
Ash_89 (05-18-2021), boy_racer (05-18-2021), Copy (05-18-2021), Dzmitry (05-18-2021), HKz (05-17-2021), Lantanafrs2 (05-18-2021), PulsarBeeerz (05-22-2021), WildCard600 (05-17-2021)
Old 05-18-2021, 07:54 AM   #534
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by timurrrr View Post
And 7400 rpm redline...
Feels like some marketing intern messed up when copy-and-pasting things between PowerPoint presentations?
Lol... at this point, even when the cars are fully released and specs are "confirmed", I still won't know what to believe
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Tcoat (05-18-2021)
Old 05-18-2021, 10:48 AM   #535
Make's it hard for me to rag on the clickbaits when Subaru/Toyota can't say the same thing twice in a row!
Dadhawk (05-18-2021), Dzmitry (05-19-2021), Spuds (05-18-2021)
Old 05-18-2021, 11:09 AM   #536
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I have faith that you'll somehow still find a way.
Cephas is offline   Reply With Quote
The Following 2 Users Say Thank You to Cephas For This Useful Post:
Ash_89 (05-18-2021), Tcoat (05-18-2021)
Old 05-18-2021, 02:37 PM   #537
twodollarcuts
Drives: Subaru BRZ Limited
I feel like a lot of the 4's are a pride thing. I keep telling myself my BRZ looks better but when I initially see these new models I think that they are very nice. Would love the instrument cluster and I'd take a steaming pile of dog sh*t over my stock head unit so I'd definitely take that, too.
twodollarcuts is offline   Reply With Quote
Old 05-18-2021, 06:28 PM   #538
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I find the GR 86 better-looking than the GR Supra. Once your brain processes that the GR Supra’s headlights are oversized for the width of the front bumper, it just starts looking awkward especially when the nose comes in.
I’m not hating on the design but when I see the clean, simple front-end of the GR 86 right next to it, it’s not hard to realize how busy the GR Supra is and makes it easy to appreciate clean & simple designs.
Veloist is offline   Reply With Quote
The Following User Says Thank You to Veloist For This Useful Post:
Cephas (05-18-2021)
Old 05-18-2021, 07:46 PM   #539
Yoshoobaroo
TRACKBREAD
Originally Posted by Veloist View Post
I find the GR 86 better-looking than the GR Supra.]
I don't think that's a controversial opinion.
Old 05-18-2021, 08:06 PM   #540
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Red-86 View Post
0-60/0-100 times are funny, they are all over the place. Some manufacturers underrate, some overrate, so it is difficult to compare official numbers. Only way to be sure is test the cars back to back on the same track, on the same day with the same driver and testing gear. Anything else is subject to too much variance and uncertainty.
Whilst it would be great to see a full 1 sec improvement in the 0-100 time, I’m also sceptical. That’s a significant reduction for a fairly modest power and torque bump, but maybe it’s possible. More importantly the added torque should make the car feel stronger in routine driving. The twins were never the car to get for rapid acceleration and drag races from red lights - so many quicker cars around for that.
Its the weight being so low still. I can totally believe those numbers.
The base GR86 actually has a greater power to weight than a base WRX here in Australia.
WRX 1447kg @ 197kw = 136.14 kw/t
GR86 1270kg @ 173kw = 136.22 kw/t
Blighty is offline   Reply With Quote
Old 05-19-2021, 08:16 AM   #541
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Power figures doesn't mean much alone, unless you are looking for top speed numbers. It is the power to weight ratio that matters most.
The Following User Says Thank You to nikitopo For This Useful Post:
Tcoat (05-19-2021)
Old 05-19-2021, 08:55 AM   #542
And manufacturer rated power figures mean even less. What it puts out at the crank can be radically different from what it puts to the ground.
nikitopo (05-19-2021)
Old 05-19-2021, 10:14 AM   #543
Blighty
They are good indicators, nothing is perfect. I mean the WRX will probably lose more through the drivetrain than the GR86 owing to AWD (I assume this is still the case anyway), but I'd still expect it to be pretty close.
Yes power to weight is far better and more relevant than just power or torque to assess performance, but even inside this metric its not perfect.
As its based off a peak figure (even if its combined with a figure that isn't), it still suffers from the same bugbear as when we use ANY peak figure - it matters what the power was across the WHOLE rev range of your required application, not just the peak. No doubt the WRX would have a good chunk of near to full power for larger (if lower down) part of the revs when daily driving. On the track a little less advantageous.
But anyway, the FACT that we are thereabouts to the performance of a ~265hp WRX turbo with just a NA boxer 4 pot is freaking awesome in my books.
Old 05-19-2021, 10:37 AM   #544
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
The improved tires (assuming they timed this on a car on the PS4s) would help too.
On the 0-60s, even magazines are wildly-inconsistent (some of them allow a few feet rollout before they start the clock, some of them will dump the clutch or abuse the car for the best possible time, etc)
daiheadjai is offline   Reply With Quote
Old 05-22-2021, 01:50 PM   #545
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Found the 2022 Toyota Supra Turbo
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following 3 Users Say Thank You to blackhawkdown For This Useful Post:
Ash_89 (05-24-2021), JesseG (05-23-2021), mazeroni (05-22-2021)
Old 05-23-2021, 10:46 AM   #546
mn_ca
Drives: 2013 frs, 2005 is300
This car looks so simple and elegant. It's gonna sell.
mn_ca is offline   Reply With Quote
The Following 2 Users Say Thank You to mn_ca For This Useful Post:
beltax90 (05-23-2021), gymratter (05-24-2021)
GR (Gazoo Racing) Front Lip: 2017+ Toyota 86 TylerLieberman Exterior Parts (Aero, Lighting, Etc.) 3 10-09-2020 10:46 PM
TOYOTA GAZOO Racing WINS LE MANS gymratter Other Vehicles & General Automotive Discussions 18 06-20-2018 10:42 PM
Mega Web: Toyota 86 14R, Gazoo Racing 86 Concept, and Gazoo Racing 2012 GT86 #165 mav1178 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 09-03-2015 10:24 AM
Toyota Gazoo Racing Festival 11-25-2012 switchlanez Scion FR-S / Toyota 86 GT86 General Forum 2 11-25-2012 03:11 AM
Toyota Gazoo Racing Festival Stream ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-24-2012 10:52 PM
