Old 05-17-2021, 10:50 AM   #169
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Damn sorry to see this. I definitely used your build as inspiration for mine in a few areas. Well I know now to keep my current conservative tune for my edelbrock. I'll be looking forward to see what you do next since my motor probably isn't too far behind yours since I'm pushing 166k on the motor.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 05-17-2021, 11:05 AM   #170
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The audio is interesting. Trying to sort out the RUD (Rapid Unscheduled Disassembly) process is even more so. I really wonder what broke first. The most obvious candidate is the rod, but I kinda wonder about the piston.
In the end, I've concluded that when you boost one of these things, it becomes something like a Schrodinger's engine. Both alive and dead - depending on an event which may not happen.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-17-2021, 06:07 PM   #171
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The audio is best heard with quality headphones. They whistling shreak before destruction makes me think the oil barrier failed. Was it oil starvation, cold oil, cumulative/chronic excessive stress, detonation or preignition excessive stress…? I don’t know. Maybe it was a combination of things, but what I can’t wrap my head around is how that piston was destroyed.
I feel like if it was too much cylinder pressure from detonation or preignition then the excessive heat and pressure would have been revealed itself in damage to the top of the piston, but there was none outside of a clear, single, strike marks from the valves, and the damage was mostly from the bottom. It is odd.
The pictures of this bent rod and the destroyed bottom of the piston (see below) give credence to the theory that my connecting rod could have bent enough to cause piston damage, and then ripped apart as it nunchucked in the block after destroying the piston. How else could that have happened? It actually makes sense too because if there were high forces that would cause compression to the rod, but if it bottomed out against the bearing then there would have been an instant of rotational/sheer force leading to bending maybe. I’ve seen bent rods from FA20s, so it is possible. Plus, the head of my rod bolt snapped off like this guy, so lots of similarities.
https://www.eng-tips.com/viewthread.cfm?qid=385394
Old 05-18-2021, 12:04 PM   #172
Capt Spaulding
Persona Non Grata
The condition of the piston is what I have found puzzling. It appears to have been damaged from below - almost as if it broke at the wristpin journal.
My thoughts exactly.
https://www.eng-tips.comThe/viewthread.cfm?qid=385394
This is makes sense to me. The link was quite interesting. The idea that the piston broke under tension was one of my first reactions. Still, I have no clue why.
Old 05-18-2021, 01:45 PM   #173
Irace86.2.0
The link makes it clear that the piston could bend in any direction under load. Maybe my piston bent from fatigue under load, and then it caused the whistling grind before catastrophic failure.
I feel like bearing failure on a single cylinder from oil starvation is unlikely under the conditions I was in, but possible, and it is unlikely to cause total catastrophic failure, IMO, and not just rod knock or something.
It seems more likely that the rod bent from high pressure and chronic fatigue, and then it caused pressure to build on the rod bearing, and then the harmonics and internal forces ripped the rod from the bottom of the piston, and then the rod tore through the block, breaking apart in the process. That is my best guess.
Old 05-18-2021, 02:56 PM   #174
Capt Spaulding
Persona Non Grata
Works for me. It was an impressive failure. I wonder what the fatigue life on these pistons is? Also, might the increased thermal (and possibly shock) load boost puts on them shorten that life?
Old 05-18-2021, 09:47 PM   #175
Irace86.2.0
They are cast aluminum pistons, right? I don't know, but this gives credence to the idea that pistons need to be upgraded along with rods. Under normal wear and tear, I think the weakest link is the piston skirt. They have a tendency to accumulate the most wear, and they probably see the most lateral forces, but I think anything can develop fatigue. It probably depends on the engine and the type of wear/abuse it is seeing, which may be similar across drivers or unique to certain drivers.
https://www.irjet.net/archives/V3/i4/IRJET-V3I4330.pdf
Check out some of these pictures. Because the other pistons/rods were fine, I am thinking this was less of a power issue like the guy in the link and more of a single cylinder event brought on by oil starvation to that bearing and potentially cumulative wear to the bearing or something just mildly out of tolerance.
https://www.ft86club.com/forums/showthread.php?t=49767
Old 05-19-2021, 01:36 PM   #176
Capt Spaulding
Persona Non Grata
I suspect a rod bent like that would cock the piston in the cylinder generating all sorts of stresses on the piston and the rod. From there - several things could break. Your experience (along with others) has convinced me to forego boosting this engine. If I were to consider it, I think good rods (e.g. Carrillio) and good forged pistons would be on my list of requirements.
Old 05-19-2021, 03:16 PM   #177
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Can we get head on shots off the rod pieces.
I'd like to see the marks where they rod came apart.
Old 05-19-2021, 04:20 PM   #178
Irace86.2.0
I think a bar of boost with E85 and a header is too much. A basic CARB kit on pump gas or E85 that is just a daily driver and not a track car will probably last the life of the car.
Old 05-19-2021, 04:23 PM   #179
Irace86.2.0
I'll work on that later, but the two ends probably aren't the two ends that fractured. I am missing some of the middle of the rod, so it either broke in multiple pieces, or after it broke, it was again torn apart, as it sliced through the block.
Old 05-19-2021, 04:27 PM   #180
Irace86.2.0
Thinking of pulling the trigger on a G25-660 0.72ar. It has the response and enough top end for a K24 build and for any future builds. Crazy how much power these new small turbos are making.
https://chromjuwelen.com/items/item/...70-whp-on-dyno
Old 05-19-2021, 06:54 PM   #181
It definitely could have been slowly getting worse and worse, but then it finally gave out. Perhaps it didn't have a chance to knock because it caused immediate failure. I really can't remember, but I believe the bearing was in place, and I know the rod that snapped could freely spin around the journal, but another part of me thinks the bearing could have rotated about 5-10mm out of position. I remember one bearing being like that, but I couldn't recall if it was from the broken rod or another and just a product of the disassembly. What is obvious is that the tort head of one of the rod bolts snapped off. When, I don't know. The journal wasn't visually that damaged, unlike the bearing, but maybe because it is forged, it survived better, and maybe the bearing heated up or something, but it wasn't like I was driving for miles or weeks with rod knock like people can do.
The oil was recently changed and good, but it may have been too cold, and I could have sloshed the oil going through the 'S' curve of the left, right, right turn, but I typically need to wait for the car to clear the bucked asphalt at the apex of the corner, or the car just will lose traction. Typically, I would hit the bump then wait a second for the car to straighten out before getting on it, and that seems to be mostly the case, so while it is possible the oil starved because of lateral movement, mixed with cold temps, I just don't know.
Here is the thing: I have been listening to the video over and over. Unfortunately, the video is just from a dash camera from inside the car, and there is music and loud road noise. I used Audacity to try to isolate the sound, and when I did the best I could, I can swear I hear a squeal/whistle before the engine explodes. The squeal/whistle could be the tires breaking loose a little, but this is unlikely, as that would have decreased the stresses on the motor, so it is more likely that the squeal/whistle could be bearing surface contact. Maybe there was too much force and not enough oil to protect the surface, and once the surface made contact under high load, it set off a chain of events that caused the failure.
Listen to the audio. There is a squeal right before the destruction. Still, I don't get how the rod tore through the bottom of the piston and then disintegrated in half, or did it disintegrate and then stick the piston? Who knows?
I am of the opposite opinion. Rod snapped. Took out bearing. Launched piston into valves. Then slapped around in there for a bit creating the rest of the mess. I did it more than once a few decades ago. Classic results.
Old 05-20-2021, 12:50 AM   #182
Irace86.2.0
Here you go sir. On a closer inspection, the rod is bent to the side. It is subtle, but it is there. This bending is 90 degrees to the direction it was spinning. This suggests the bending wasn’t a consequence of spinning around and tearing through the block. Like nunchucking through the block happened, and it probably finished the rod off, but I bet the bend caused the internal stress on the piston and ripped the bottom of the piston to pieces and then it all went downhill from there.
Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) DustinS Member's Car Journals 800 04-13-2024 09:23 AM
Engine Blew, any shop recommendations? tian105 Southern California 11 08-16-2020 11:35 PM
Engine blew on 4psi? Causes? soccerk18 Software Tuning 26 08-10-2019 11:18 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
